I recently purchased part number wb20x107 spark module by GE. The model number I listed above for the kenmore countertop should be correct. I am having trouble wiring the spark module correctly. Could someone please explain the correct way to install this piece? Thank you.
It is a gas cooktop. I may be incorrect on the actual model number I listed. Here is another number found on the appliance 9114742992.
