Discuss
Oven not lighting after gas turned off then on
 in
I have an Americana gas range and oven. I turned off the gas service at the meter to do some
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not lighting after gas turned off then on
  #1 (permalink)
Old 11-10-2008, 08:39 AM
Junior Member
nbrock51 is on a distinguished road
Default Oven not lighting after gas turned off then on
Brand: -other-   Age: 1 - 5 years
I have an Americana gas range and oven. I turned off the gas service at the meter to do some work. When I turned the gas back on, I had to light the pilot lights for the range. When I tried to light the pilot for the broiler and oven, it will not light, and there is also no gas coming out of the oven burners when I turn the oven on. The range burners work fine. Is there some other reset button or vlave I need to find to get the oven working too?
  #2 (permalink)
Old 11-10-2008, 08:51 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Do you still have the owners manual, There is a process to get it lit and it's in there. I'll see if I can find the instructions.
__________________
  #3 (permalink)
Old 11-10-2008, 08:58 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Push in the oven control knob while lighting the pilot, after the pilot is lit, continue pushing the knob in for 1 minute, when released after a minute the pilot should stay lit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Roars when turned on margie765 Oven Repair (including Ranges and Cooktops) 1 01-29-2009 04:25 PM
GE oven heats when turned off!! bbeins@frontiernet.net Oven Repair (including Ranges and Cooktops) 1 12-24-2008 02:55 PM
Oven turned on by itself jbhurt Oven Repair (including Ranges and Cooktops) 1 10-11-2008 06:02 PM
Clock turns on when the oven is turned on but oven doesn't work LMesey Oven Repair (including Ranges and Cooktops) 2 08-22-2008 11:20 AM
Oven buzzing when turned on julsbythesea Oven Repair (including Ranges and Cooktops) 1 02-06-2008 03:42 PM
