Discuss
Whirlpool Oven RBS305PRS00 not heating
 in
I ran the self-clean function on my oven this weekend with no problems at all. I have used the self-clean
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Oven RBS305PRS00 not heating
  #1 (permalink)
Old 11-18-2010, 09:14 PM
Junior Member
loril is on a distinguished road
Default Whirlpool Oven RBS305PRS00 not heating
Model Number: RBS305PRS00   Brand: Whirlpool   Age: 1 - 5 years
I ran the self-clean function on my oven this weekend with no problems at all. I have used the self-clean function in the past with no issues, as well. Tonight in an effort to bake a casserole for a work Thanksgiving function tomorrow at work, I turned on my sparkling clean oven. I heard the fan kick on to circulate the air and thought nothing else of it. And ten minutes later when I was ready to put my casserole in my pre-heated oven, I noticed that the oven was not even remotely hot. In fact, I could touch the heating element with no concern.
Please tell me this is an easy fix (and cheap)! We are hosting Thanksgiving for 18 people and it's just a week away.
The oven is a Whirlpool brand, model RBS305PRS00. It is 4.5 years old. In efforts to determine the problem and maybe trick it into working, I have also noticed that the broiler element is also not working.
Ads By Google
Related Models
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
Amana RC-14B Commercial Microwaves
Amana RC-14S Commercial Microwaves
Amana RC-14SD Commercial Microwaves
Amana RC-14SE Commercial Microwaves
Amana RC-14T Commercial Microwaves
Amana RC-14TD Commercial Microwaves
Amana RC-14TE Commercial Microwaves
Amana RC-20 Commercial Microwaves
Amana RC-20SE Commercial Microwaves
Amana RC-6D Commercial Microwaves
Amana RC-6PB Commercial Microwaves
Amana RC-7D Commercial Microwaves
Amana RC-7PB Commercial Microwaves
Amana RC-8 Commercial Microwaves
Amana RC04880A1D Room Air Conditioner
Amana RC04880A1D REV Room Air Conditioner
Amana RC04880A1DR Room Air Conditioner
Amana RC04880A1DR REV Room Air Conditioner
Amana RC04880A1E Room Air Conditioner
Amana RC04880A1X Room Air Conditioner
Amana RC04880A1X REV Room Air Conditioner
Amana RC04880A1XR Room Air Conditioner
Amana RC04880A1XR REV Room Air Conditioner
Amana RC05010A1D Room Air Conditioner
Amana RC05010A1D REV Room Air Conditioner
Amana RC05010A1DR Room Air Conditioner
Amana RC05010A1DR REV Room Air Conditioner
Amana RC05080A1X Room Air Conditioner
Amana RC05080A1XR Room Air Conditioner
Amana RC05080M1D Room Air Conditioner
Amana RC05080M1D Rev Room Air Conditioner
Amana RC05080M1D Rev A Room Air Conditioner
Amana RC05080M1DR Room Air Conditioner
Amana RC05080M1DR Rev Room Air Conditioner
Amana RC05080M1DR Rev A Room Air Conditioner
Amana RC05090A1D Room Air Conditioner
Amana RC05090A1D REV Room Air Conditioner
Amana RC05090A1DR Room Air Conditioner
Amana RC05090A1DR REV Room Air Conditioner
Amana RC05090M1D Room Air Conditioner
Amana RC05090M1D Rev Room Air Conditioner
Amana RC05090M1D Rev A Room Air Conditioner
Amana RC05090M1DR Room Air Conditioner
  #2 (permalink)
Old 11-19-2010, 03:38 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBS305PRS00 30" Built - in Electric Oven Self Clean | AppliancePartsPros.com
This should come in handy.
https://secured.whirlpool.com/Servic...LE/8178007.pdf
First check the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If power is OK then check the hi-limit thermostat (Item 37 in Section 1).
Safest way to doo this is remove power from the unit (flip the breaker off) and measure it with a meter, should be 0 ohms,
Sorry I do not know anyway to trick the unit into working.
__________________
  #3 (permalink)
Old 11-19-2010, 04:49 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
let me help you if you don't have a meter. Take the 2 wires off of the thermostat, Mr Denman is telling you about, of course the power is off, and put the terminal ends together, and put some tape around it to keep them together, and to be sure they don't hit metal, and then turn the power on, and see if it heats. If it does, you need to replace the thermostat, and the sensor, because when you put the oven in clean, it got to hot a blew the sensor. You have to replace them both. If you don't, the next time you put it in a clean cycle, it will blow the thermostat again. Tom ********************************************
  #4 (permalink)
Old 11-22-2010, 07:01 PM
Junior Member
Default An update to this situation
We replaced the thermostat only thinking that we probably won't use the self-clean function in the future if this is going to be the result of that effort.
We did invest in a little-sufficient-for-home-use multimeter and were able to determine that the original thermostat really was dead. We also checked our circuit breaker to ensure that it was not our problem, as well as both the bake and broil elements as we were looking for anything other than the control panel to be our problem.
After we replaced the thermastat and turned the power back on at the breaker, we started the oven up to see if it was working.
It did not work. So we continued to investigate. We ultimately were about ready to replace the control panel and then decided to check the oven just one more time. With it all put back together again and the breaker back on again, we turned it on again. And this time it worked!
Really, the only thing that changed was the breaker had been tripped a couple of times between the first check and the end result of having a working oven back.
And I still think we probably won't be using the self-cleaning function anymore. Because of the time constraints of Thanksgiving being upon us we wound up using a local parts store to buy our replacements and the guys at that shop told us that Whirlpool (and all subsidiaries) is notorious for burnt out thermostats. The self-clean function is just not worth this hassle!
  #5 (permalink)
Old 11-23-2010, 04:16 AM
Senior Expert
APP Volunteer
Default
Awesome!! The self clean function is great when it works. When it breaks, it's expensive. If the temp is off in any way, I believe on the model if you hold the Bake button down for 5-10 seconds, a zero will come up, and then you can hit the up or down buttom to raise or lower the temperature, and then hit start, and it will hold the new adjustment. Then hit the bake button again, to make sure it has the amount you went up or down. If not, the do all I said, and the last thing you do, instead of hitting the start button, you hit the bake button. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven not heating kmbrlyfrantz Oven Repair (including Ranges and Cooktops) 3 11-28-2010 07:07 PM
Whirlpool in-wall oven not heating BJF Oven Repair (including Ranges and Cooktops) 14 09-12-2010 02:01 PM
Please Help!! Whirlpool gas oven not heating correctly Rebetimm Oven Repair (including Ranges and Cooktops) 1 08-24-2010 09:53 AM
Whirlpool Oven Not Heating Properly Jinsmom Oven Repair (including Ranges and Cooktops) 1 01-12-2010 02:54 AM
whirlpool oven not heating Garrot Oven Repair (including Ranges and Cooktops) 0 04-02-2009 05:50 PM
