When I turn on the oven, nothing happens. It does not ignite. I called a Sears authorized repair service. The repairman that came out did not actually check anything, he only listened to our discription of the problem and said that we needed a new control panel. He said they run about $600.00 but he thought he could get one for about $400.00. He said he didn't think it was worth it and suggested that we buy a new oven. For that he collected $90.00. We purchased a new control panel through you for approximately $65.00 and installed it. The oven doesn't work. We have installed a new temp. sensor and the oven still doesn't work. Now we're thinking "igniter". Any suggestions? Thank you for your help.
