Discuss
error code E1 F2 on whirpool gas range
 in
I have an whirpool double oven with a e1 f2 code. Their are a few buttons that don't respond
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » error code E1 F2 on whirpool gas range
  #1 (permalink)
Old 11-09-2008, 12:43 AM
siciliano siciliano is offline
Junior Member
siciliano is on a distinguished road
Default error code E1 F2 on whirpool gas range
Model Number: rbd245pd   Brand: Whirlpool   Age: 5 - 10 years
I have an whirpool double oven with a e1 f2 code. Their are a few buttons that don't respond to touch also. I've researched the code and it says its either a loose touch pad conn. or it needs a new touch pad. I tried cleaning the connection and its still doing the same thing.
My question is how do i know its the touch pad and not control panel or both. PLEASE HELP!
Phil
Related Models
Whirlpool RBD245PDB1
Whirlpool RBD245PDB10
Whirlpool RBD245PDB11
Whirlpool RBD245PDB12
Whirlpool RBD245PDB14 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDB15 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDB2
Whirlpool RBD245PDB3
Whirlpool RBD245PDB4
Whirlpool RBD245PDB6
Whirlpool RBD245PDB7
Whirlpool RBD245PDB8
Whirlpool RBD245PDB9
Whirlpool RBD245PDQ1
Whirlpool RBD245PDQ10
Whirlpool RBD245PDQ11
Whirlpool RBD245PDQ12
Whirlpool RBD245PDQ14 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDQ15 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDQ2
Whirlpool RBD245PDQ3
Whirlpool RBD245PDQ4
Whirlpool RBD245PDQ6
Whirlpool RBD245PDQ7
Whirlpool RBD245PDQ8
Whirlpool RBD245PDQ9
Whirlpool RBD245PDS12
Whirlpool RBD245PDS14 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDS15 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDT10
Whirlpool RBD245PDT11
Whirlpool RBD245PDT12
Whirlpool RBD245PDT14 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDT15 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PDT8
Whirlpool RBD245PDT9
Whirlpool RBD245PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PRS01 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD245PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB1
Whirlpool RBD275PDB10
Whirlpool RBD275PDB11
Whirlpool RBD275PDB12
Whirlpool RBD275PDB13
Whirlpool RBD275PDB14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB2
Whirlpool RBD275PDB3
Whirlpool RBD275PDB4
Whirlpool RBD275PDB6
Whirlpool RBD275PDB7
Whirlpool RBD275PDB8
Whirlpool RBD275PDB9
Whirlpool RBD275PDQ1
Whirlpool RBD275PDQ10
Whirlpool RBD275PDQ11
Whirlpool RBD275PDQ12
Whirlpool RBD275PDQ13
Whirlpool RBD275PDQ14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ2
Whirlpool RBD275PDQ3
Whirlpool RBD275PDQ4
Whirlpool RBD275PDQ6
Whirlpool RBD275PDQ7
Whirlpool RBD275PDQ8
Whirlpool RBD275PDQ9
Whirlpool RBD275PDS12
Whirlpool RBD275PDS14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDS15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT10
Whirlpool RBD275PDT11
Whirlpool RBD275PDT12
Whirlpool RBD275PDT13
Whirlpool RBD275PDT14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT8
Whirlpool RBD275PDT9
Whirlpool RBD275PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS01 27" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool RBD275PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD276PDB1
Whirlpool RBD276PDB10
Whirlpool RBD276PDB11
Whirlpool RBD276PDB12
Whirlpool RBD276PDB2
Whirlpool RBD276PDB4
Whirlpool RBD276PDB6
Whirlpool RBD276PDB7
Whirlpool RBD276PDB8
Whirlpool RBD276PDB9
Whirlpool RBD276PDQ1
Whirlpool RBD276PDQ10
Whirlpool RBD276PDQ11
Whirlpool RBD276PDQ12
Whirlpool RBD276PDQ2
Whirlpool RBD276PDQ4
Whirlpool RBD276PDQ6
Whirlpool RBD276PDQ7
Whirlpool RBD276PDQ8
Whirlpool RBD276PDQ9
Whirlpool RBD277PDB1
Whirlpool RBD277PDB2
Whirlpool RBD277PDB4
Whirlpool RBD277PDQ1
Whirlpool RBD277PDQ2
Whirlpool RBD277PDQ4
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
  #2 (permalink)
Old 11-09-2008, 07:18 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Try this, and you will know which one is the problem. Tom ApplianceEducator.com
  #3 (permalink)
Old 11-09-2008, 07:23 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
I would start with the touch pad for a couple reasons you mentioned a couple others dont work and the board is giving out the code to truly verify it and its hard to do you ohm the touchpad out pressing individual pads verifying with a meter, It's luck of the draw and process of elimination if the touchpad don't work then its the board. You actually can save money having a repairman check it because it would be at his expense if he's wrong not yours........after I posted Kayacrazy has a better answer
__________________
  #4 (permalink)
Old 11-09-2008, 07:35 AM
Junior Member
Default
ITS NOT GIVING ME AN F1 CODE,,, iTS AN "F2, E1" Please respond.
  #5 (permalink)
Old 11-09-2008, 07:38 AM
Junior Member
Exclamation
I did disconnect the touch pad from the control panel, powered it up, got a pf and in a minute got the same "E1,F2".
  #6 (permalink)
Old 11-09-2008, 09:11 AM
Senior Expert
APP Volunteer
Default
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
This is what the manual says on how to check, which conponent is bad. This is for the E1,F2 symptom. The one is sent you is a general one. This is what the manual says, for your specific code. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
f2 error code hotpoint range honeypot Oven Repair (including Ranges and Cooktops) 4 11-27-2008 08:02 AM
Jenn Air range error code F1-8 when hot JimSimpson Oven Repair (including Ranges and Cooktops) 1 09-25-2008 10:19 PM
WP Range Error Code E2/F3 go2geye Oven Repair (including Ranges and Cooktops) 1 04-24-2008 11:05 PM
Error F1 E1 on Whirpool Range/Oven Natasha1979 Oven Repair (including Ranges and Cooktops) 1 03-21-2008 12:50 PM
F2 Error Code for Kenmore Range familykg Oven Repair (including Ranges and Cooktops) 1 01-21-2008 01:46 PM
