Temp control up down keys on the (I believe) oven membrane switch panel will not function. All other touch keys function. Any ideas as to what needs to be replaced? Thanks
Most likely either a bad connection from touch pad to control board, or a bad touch pad. This one might be worth having an authorized Dacor tech come and diagnose. Parts are very expensive, and you don't want to be throwing parts at this repair.
