| » fault codes |
Model Number: ww27430w Brand: Jenn-Air Age: More than 10 years
Hello. trying to determine the steps to repair my oven. local repair people are reluctant to come out and keep advising me to buy parts in a ( poke and hope) scenerio. getting specific fault codes of f5 on the top oven and fr on the bottom. This site does not list my model to suggest what to do in regards to these fault codes. Any suggestions?
There are two relay boards (one for each oven). They both are located behind the control panel on the right side.
There is an oven temperature sensor in each oven. The "F5" error code means "Power to element relays disabled in cook mode". Check the oven sensor plugs and all relay board wire harness for a tight connections. The "FR" error code for the lower oven has the same meaning and requires the same actions. In case if there is nothing wrong found, replace both relay boards. - The upper oven relay board Part number: AP4098257 - The lower oven relay board Part number: AP4009507 Here are the breakdown diagrams and Replacement parts for JENN-AIR WW27430W Walloven - S/c Ele | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
| Display Modes | |
| F1-1, F1-2, F3-2 Fault Codes | pjc97009 | Oven Repair (including Ranges and Cooktops) | 0 | 11-15-2010 01:47 PM |
| Magic Chef fault codes | jimgeraets | Oven Repair (including Ranges and Cooktops) | 0 | 09-30-2010 04:16 AM |
| Temperature Control & Fault Codes | alex_ny | Oven Repair (including Ranges and Cooktops) | 0 | 06-06-2009 06:50 AM |
| Fault Codes and Beeps | hesper73 | Oven Repair (including Ranges and Cooktops) | 1 | 03-31-2009 06:41 AM |
| Dryer Fault Codes | kayyjohnston | Dryer Repair | 1 | 01-08-2009 05:15 AM |
