Julio
#1 Posted : Tuesday, November 16, 2010 4:21:57 PM(UTC)
Julio
Hello!
We have a Whirlpool Gold Accubake System oven, Model GBS307PDQ9.
My wife run a self cleaning cycle, and since that adventure, the oven does not work anymore.
All the electronic part of it seems like working fine, but it doesn't heat up at all.
I was reading at your articles where it seems like a lot of folks are having the same type of problem; But I decided to contact you and ask due to that there maybe different parts that are applicable based on the Model.
I appreciate any information on this item.
Thanks.
Julio
#2 Posted : Wednesday, November 17, 2010 3:52:26 AM(UTC)
Replacement parts for WHIRLPOOL GBS307PDQ9 | AppliancePartsPros.com
Sounds like the high limit thermostat (Item 37 in Section 1) has opened.
I would check the power to the unit first. Electronics and lights only require half the line (120 volts) whkile the elements require bothe sides (240 volts)
See bootom of this post,
Looks like this is sold as single or dual oven units.
Remove power from the unit.
Remove one wire from the thermostat and check it with a meter.
Should be 0 ohms.
This should help with your repair.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Power Check
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Whirlpool Wall Oven Dead After Self Cleaning Cycle (Oven Repair (including Ranges and Cooktops))
by Mattstone87 10/25/2019 3:45:35 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
My Range stopped working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Eternalsnshine 10/25/2016 12:17:59 PM(UTC)
self cleaning option does not work (Oven Repair (including Ranges and Cooktops))
by jackbuettner@msn.com 10/6/2016 1:03:43 PM(UTC)
Kitchenaid self cleaning issue (Oven Repair (including Ranges and Cooktops))
by jon1954 6/14/2015 12:02:05 PM(UTC)
GE stove. Self cleaning not working (Oven Repair (including Ranges and Cooktops))
by dihahey 6/9/2015 4:31:34 PM(UTC)
Kenmore Elite Electric Range - lower oven does not work after "self cleaning" cycle (Oven Repair (including Ranges and Cooktops))
by AKJim 11/23/2014 5:19:54 PM(UTC)
self cleaning not working (Oven Repair (including Ranges and Cooktops))
by novice mike 11/18/2014 12:02:00 PM(UTC)
Wall Oven Dead after self cleaning (Oven Repair (including Ranges and Cooktops))
by PKABS1 8/1/2014 6:05:10 PM(UTC)
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 4/6/2014 2:22:53 PM(UTC)
JennAir Oven Self Cleaning Troubleshooting (Oven Repair (including Ranges and Cooktops))
by lylecm 4/3/2014 2:22:13 PM(UTC)
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 3/18/2014 6:25:03 PM(UTC)
Self cleaning problem (Oven Repair (including Ranges and Cooktops))
by ve2zc 3/13/2014 11:24:43 AM(UTC)
Troubleshoot Self cleaning oven (Oven Repair (including Ranges and Cooktops))
by mluster1 2/27/2014 9:35:20 AM(UTC)
