CJ1959
#1 Posted : Tuesday, November 16, 2010 1:07:23 PM(UTC)
CJ1959
I have a GE Gas Range - JGBP31We4 - a few weeks ago I used the self clean and since then the oven will not work. I cycled the self clean mode again and it work fine so I believe the igniter works, but when I tried to use the oven it would not ignight.. I have lubed the lever already and that did not work.. is it worth fixing or should I just get anew one?.
#2 Posted : Tuesday, November 16, 2010 8:08:24 PM(UTC)
Possible the door latch handle is bend toward open position and the latch would not open completely, causing the latch switch not to engage properly. Try to accurate push the door latch handle in the opposite direction to unbend it.
Here are the breakdown diagrams and Replacement parts for General Electric JGBP31WEC4WW Gas range | AppliancePartsPros.com
blinking clean light (Dishwasher Repair)
by suzchris 8/9/2017 2:58:19 PM(UTC)
blinking clean light - what to check next (Dishwasher Repair)
by signal 9/21/2012 7:24:23 AM(UTC)
blinking clean light won't shut off (Dishwasher Repair)
by jackwolfe 8/5/2011 11:52:50 AM(UTC)
Kenmore DW blinking Clean light (Dishwasher Repair)
by Badabinbg 9/14/2009 6:51:48 AM(UTC)
Blinking Clean light after installing new control module (Dishwasher Repair)
by parrottf 5/30/2008 6:23:09 PM(UTC)
Kenmore Blinking Clean Light (Dishwasher Repair)
by caste 1/31/2008 9:14:37 AM(UTC)
