Discuss
Kitchen Aid oven not working
 in
The range/oven was working perfectly until we had an electrical storm with a couple of close lightning strikes. Now,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchen Aid oven not working
  #1 (permalink)
Old 10-03-2007, 08:53 PM
Hortdude Hortdude is offline
Junior Member
Hortdude is on a distinguished road
Default Kitchen Aid oven not working
Model Number: KGRC608LSSO   Brand: Kitchen Aid   Age: 1 - 5 years
The range/oven was working perfectly until we had an electrical storm with a couple of close lightning strikes. Now, only the top burners work. The entire electronic display is blank and does not respond to pressing any button. The oven does not light or do anything. Do I need to replace the microprocessor, the control board, or something else? Of coarse I double checked that the power is on to the unit.
Thanks in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 11:29 PM
bjv bjv is offline
Junior Member
bjv is on a distinguished road
Default
try turning the breaker off for a few minutes then turn back on sometimes static builds up in the microprosesor and the control does not know what to do so the unit goes dead by cuting power to the unit it allows static to clear this is pretty comon with electrical storms
  #3 (permalink)
Old 10-04-2007, 06:52 AM
Junior Member
Default Kitchen Aid Gas Oven not working still
Thanks for your reply. I tried disconnecting the power for a while and it still does not work. I should have mentioned it is an LP gas unit. The top burners ignite and burn properly, but the electronic display is blank and there is no way to operate the oven. Any ideas?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:22 PM
Oven not working on JennAir range darnote Oven Repair (including Ranges and Cooktops) 0 09-05-2007 09:05 AM
oven not working Charlie Oven Repair (including Ranges and Cooktops) 0 09-02-2007 08:17 AM
Oven Not Working strahmdonna Oven Repair (including Ranges and Cooktops) 1 08-30-2007 08:41 PM
Oven light and outlet not working happydog Oven Repair (including Ranges and Cooktops) 0 08-24-2007 10:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
