Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Electronic oven control assembly I did something wrong... (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/14273-electronic-oven-control-assembly-i-did-something-wrong.html)
Gary Hagen 11-08-2008 03:03 AM
We received a new Electronic Oven Control Assemby from your company. Because the light went out. After putting in the ribbon and plug ins installed lock to lock. I must have done something wrong because all that works is the oven light which I cannot turn off and the clock that blinks and the rest of the oven doesn't seem to work . need help???
Thank you
gary
richappy 11-08-2008 03:33 AM
Remove the schematic you will find behind the door and check for a module wiring mistake.
