None
OVEN FAN IS ON ALL THE TIME. ERROR "F1". WHAT IS PART #FOR TOUCH PAD OR ERC? THANK YOU:confused:
Quote:
RG, The F1 code indicates a stuck relay on the ERC. The cooling fan on, all the time could also be due to a stuck relay and or a bad oven temp. sensor Part number: AP4009009 I would reccomend you check your sensor resistance first (it could also trigger a F1 code). The sensor resistance should be less than 1,100 ohms at room temperature(72dgrs). The resistance at 210 dgrs(boiling water) should be 1,350 to 1,400 ohms. If the sensor resistance checks proper, then replace the ERC. Part number: AP4427177 Good Luck, :) :) :) |
| All times are GMT -7. The time now is 11:04 AM. |
