Discuss
Thermador oven door doesn't close
 in
Just moved into an old home and discovered that the oven door doesn't close all the way. It remains
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador oven door doesn't close
  #1 (permalink)
Old 10-03-2007, 07:52 PM
deckerd deckerd is offline
Junior Member
deckerd is on a distinguished road
Default Thermador oven door doesn't close
Model Number: SC301T   Brand: Thermador   Age: 5 - 10 years
Just moved into an old home and discovered that the oven door doesn't close all the way. It remains open about 1" which lets out the heat. Any idea of the cause of this problem and the solution? I am guessing that the door hinges/springs are worn out. If you agree, how do you remove these old parts? It is not obvious from looking at the oven itself. I was able to find replacement hinges online so could order once I determine whether this is the problem and figure out how to remove/install. Many thanks for your help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 08:48 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Arrow Hinges and recpticals
I have not replaced any of these on this brand but from what I have read you will need to replace the hinges and recpticals on both sides, yours will look ok, but replacing both parts on both sides of the doors will solve your problem...do not replace the hinges without changing the recpticals, these should be available as a kit for either side...
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door Ed1848 Oven Repair (including Ranges and Cooktops) 0 09-30-2007 05:05 PM
My oven door just locked on it's own Braidqueen Oven Repair (including Ranges and Cooktops) 0 09-05-2007 02:33 PM
Oven door won't come unlocked lfox Oven Repair (including Ranges and Cooktops) 0 08-09-2007 09:32 PM
oven door locked jmiller Oven Repair (including Ranges and Cooktops) 2 07-20-2007 07:05 PM
Kitchen Aid Door doesn't close by itself GreenHorn Refrigerator & Freezer Repair 1 07-20-2007 12:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
