Our oven quit heating. Range works & display works. The oven, broiler and convection heater won't heat. 240 v to the outlet and to the buss. Is there a safety/overload somewhere in the circuit and how to test?
Does anyone have an idea?
I am assuming that the stove top works. I have tried to find a wiring diagram but have not had any success. Whirlpool has shut down their tech info site to DIYers, that is why the link DanO includes does not work. I did find the following post, like DanO I could not find the thermal limiter (cut-off) in the parts breakdown.. All I can suggest is that you try to trace the wires to see if it has one. They are usually attached to the oven case. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/39471-dead-kitchenaid-oven.htmlHopefully someone else will jump in with more/better info. |
THIS FORUM IS DEAD!!!!!!! |
In line fuse blown in red wire from buss to board. It was in the schematic but not in the parts list. I'm going to call KA and ask about the part. May just make one and make it replaceable. We are disappointed with this thing. Main control board went out in warranty, various switches shot craps, now this. Plus while moving the damn thing I found the cabinet rusted through near the top, right side just under the burners!
