Discuss
Wiring piece between Sensor Plug and Control Board?
 in
I was getting an F3 Fault Code. I replaced the Sensor. I still get an F3 Fault Code. I replaced
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wiring piece between Sensor Plug and Control Board?
  #1 (permalink)
Old 10-03-2007, 06:24 PM
Roggy Roggy is offline
Junior Member
Roggy is on a distinguished road
Unhappy Wiring piece between Sensor Plug and Control Board?
Model Number: B96070   Brand: Roper   Age: More than 10 years
I was getting an F3 Fault Code. I replaced the Sensor. I still get an F3 Fault Code. I replaced the Control Board. I still get an F3 Fault Code. I had a Service Tech come out and he found a part that he could not identify which he says is bad. There is a 3" wiring piece between the plug from the sensor and the Control Board. He says that there is no continuity from one end of the piece to the other. This piece has a 2-prong "female" plastic plug on one end (plugs into the lead coming from the Sensor) and a 3-prong "female" plastic plug on the other (plugs into the Contol Board - only 2 holes are used, the two outside holes). Inbetween the two plugs are two wires. One is a blue insulated wire and the other looks to be bare with an oversized insulation on it that reads "NE 105C L.T. 600 VW". I am assuming it may have been some type of resistor or something like that. This is the wire that doesn't have any continuity. The Service Tech can't identify it and it's not on the Parts Lists or Drawings. Does anyone know what it is and if so where can I find a new one??? Surely there's one somewhere. I'd hate to buy a new wall oven just because of this little part. HELP!!!
Related Models
Whirlpool B96070
Whirlpool B9607X0
Whirlpool B9607^0
Whirlpool B9608B0
Whirlpool B9608B3
Whirlpool B9608B4
Whirlpool B9608W0
Whirlpool B9608W3
Whirlpool B9608W4
Whirlpool B9608^4
Whirlpool B9757X0
Whirlpool B9757X1
Whirlpool B9757^0
Whirlpool B9758B0
Whirlpool B9758B3
Whirlpool B9907X0
Whirlpool B9907^0
Whirlpool B9908B0
Whirlpool B9908B3
Amana B9C2HS Room Air Conditioner
Amana B9C3EV Room Air Conditioner
Amana B9C3EW Room Air Conditioner
Amana B9C3HES Room Air Conditioner
Amana B9C3HEV Room Air Conditioner
Amana B9C3HEW Room Air Conditioner
Frigidaire B9D0 Frg(v1) / Freezer
Frigidaire B9E0 Frg(v2) / Freezer
Frigidaire B9H0 Frg(v3) / Freezer
Amana B9M32PAE Room Air Conditioner
Amana B9M32PAEH Room Air Conditioner
Amana B9M32PCE Room Air Conditioner
Frigidaire B9S0 Frg(v4) / Freezer
Frigidaire B9W0 Frg(v5) / Freezer
Maytag BA104 Washer - Top Loading
Maytag BA110 Washer - Top Loading
Maytag BA112 Washer - Top Loading
Maytag BA180 Washer - Top Loading
Maytag BA183 Washer - Top Loading
Maytag BA190 Washer - Top Loading
Maytag BA1910 Washer - Top Loading
Maytag BA209 Washer - Top Loading
Maytag BA210 Washer - Top Loading
Maytag BA211 Washer - Top Loading
Maytag BA212 Washer - Top Loading
Maytag BA282 Washer - Top Loading
Maytag BA283 Washer - Top Loading
Maytag BA284 Washer - Top Loading
Maytag BA310 Washer - Top Loading
Maytag BA312 Washer - Top Loading
Maytag BA382 Washer - Top Loading
Maytag BA390 Washer - Top Loading
Maytag BA3910 Washer - Top Loading
Maytag BA410 Washer - Top Loading
Maytag BA412 Washer - Top Loading
Maytag BA482 Washer - Top Loading
Maytag BA484 Washer - Top Loading
Maytag BA490 Washer - Top Loading
Maytag BA4910 Washer - Top Loading
Maytag BA5000 Washer - Top Loading
Maytag BA503 Washer - Top Loading
Maytag BA506 Washer - Top Loading
Maytag BA510 Washer - Top Loading
Maytag BA512 Washer - Top Loading
Maytag BA590 Washer - Top Loading
Maytag BA5910 Washer - Top Loading
Maytag BA610 Washer - Top Loading
Maytag BA612 Washer - Top Loading
Maytag BA613 Washer - Top Loading
Maytag BA6910 Washer - Top Loading
Maytag BA710 Washer - Top Loading
Maytag BA712 Washer - Top Loading
Maytag BA7300 Washer - Top Loading
Maytag BA7400 Washer - Top Loading
Maytag BA7500 Washer - Top Loading
Maytag BA7800 Washer - Top Loading
Maytag BA810 Washer - Top Loading
Maytag BA8100 Washer - Top Loading
Maytag BA8120 Washer - Top Loading
Maytag BA8140 Washer - Top Loading
Maytag BA8200 Washer - Top Loading
Maytag BA8240 Washer - Top Loading
Maytag BA8340 Washer - Top Loading
Maytag BA8420 Washer - Top Loading
Maytag BA8440 Washer - Top Loading
Maytag BA8500 Washer - Top Loading
Maytag BA8520 Washer - Top Loading
Maytag BA8600 Washer - Top Loading
Maytag BA8640 Washer - Top Loading
Maytag BA8650 Washer - Top Loading
Maytag BA8700 Washer - Top Loading
Maytag BA8740 Washer - Top Loading
Maytag BA8800 Washer - Top Loading
Maytag BA882 Washer - Top Loading
Maytag BA8820 Washer - Top Loading
Maytag BA883 Washer - Top Loading
Maytag BA884 Washer - Top Loading
Maytag BA8840 Washer - Top Loading
Maytag BA9200 Washer - Top Loading
Maytag BA9300 Washer - Top Loading
Maytag BA9400 Washer - Top Loading
Maytag BA9600 Washer - Top Loading
Maytag BA9700 Washer - Top Loading
Maytag BA9800 Washer - Top Loading
Maytag BA9900 Washer - Top Loading
Amana BB20V1E Ref - Bottom Mounts
Amana BB20V1PS Ref - Bottom Mounts
Amana BB20V1S Ref - Bottom Mounts
Amana BB20V1W Ref - Bottom Mounts
Amana BB20VE Ref - Bottom Mounts
Amana BB20VPSE Ref - Bottom Mounts
Amana BB20VSE Ref - Bottom Mounts
  #2 (permalink)
Old 10-03-2007, 08:08 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Arrow Looks like a fuse ...
According to your wiring diagram that is a fuse that opens at 102 degrees....not sure if you have to replace the wiring harness to obtain that fuse or not, will see what I can find.... CLICK HERE FOR WIRING DIAGRAM
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-03-2007, 08:22 PM
Pegi's Avatar
Senior Expert
APP Volunteer
Arrow Might do the trick...
This might, just might work in place of the fuse you now have in your range, this is for the Whirlpool ranges, Roper is made by Whirlpool, I cannot be responsable if this will not be right for your unit...
Part Details - WHIRLPOOL Fuse - thrml, part number: 9781691
__________________
  #4 (permalink)
Old 10-04-2007, 04:07 PM
Junior Member
Default
Thanks Pegi, but I don't think that will work. That piece looks like it has a ring lug on one end. And the piece I have has 2 wires with female plugs on both ends. One plug that plugs into the Sensor and the other plugs into the Control Board. Any other suggestions?????? Like I said..."Surely someone has one like this."
  #5 (permalink)
Old 10-04-2007, 07:08 PM
Pegi's Avatar
Senior Expert
APP Volunteer
Default
I do not, suspect the harness would have to be ordered, perhaps someone else will have a better suggestion...
__________________
  #6 (permalink)
Old 10-08-2007, 07:49 PM
Junior Member
Default
Still Waiting For Someone To Answer This Message That Knows How I Can Find This Part! I Thought This Was A Help Forum!?!?
  #7 (permalink)
Old 10-09-2007, 03:28 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Try pushing in on each connector pin, sometimes they get pushed out a little and fail to make contact. Also, you might try a non-residue spray combined with pushing the connectors together a few times.
__________________
  #8 (permalink)
Old 11-07-2007, 05:12 PM
Junior Member
Wink I Fixed It!!!
I fixed my problem!
It was the wiring piece that plugged in between the "Clock" and the Leads coming from the Sensor. One of the wires as I described between the plugs was a Thermal Resistor. I ordered one from Mousser Electronics and replaced it. I had to cut the old one out and the new one comes with crimp lugs. (Don't solder it or you'll blow the resistor again) I tried that. Good thing I ordered two. ($1.22 ea) I am beginning to think the problem started when we had the oven go through a "Self Clean". The high temperature must have blew the resistor. It has a different plug on each end so you can't wire/plug the sensor direct to the "Clock". You have to have this "WIRING PIECE" to connect the Sensor Leads to the Clock. The only problem I have now is the oven had a fan that turned on during use similar to a convection oven. Now the fan doesn't come on. It will if I turn the breaker off and back on but I have to push the "Cancel" button to get the fan to turn off and when I do it doesn't come back on when I push the "Bake" button to start the oven heating. My wife says it's OK if the fan doesn't work. The oven does now and we didn't have to buy a new one!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control board? rod Dishwasher Repair 1 11-05-2007 07:30 PM
Maytag control board replacement catsun54 Refrigerator & Freezer Repair 1 09-29-2007 03:55 AM
Control Board Installation Instructions tbj66 Refrigerator & Freezer Repair 3 09-11-2007 11:53 PM
Kitchenaid control board merceris Refrigerator & Freezer Repair 1 08-27-2007 10:36 AM
GE Profile Control Board ??? markham Oven Repair (including Ranges and Cooktops) 4 08-21-2007 05:15 PM
