Discuss
Wiring piece between Sensor Plug and Control Board?
 in
I was getting an F3 Fault Code. I replaced the Sensor. I still get an F3 Fault Code. I replaced
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wiring piece between Sensor Plug and Control Board?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-03-2007, 05:24 PM
Roggy Roggy is offline
Junior Member
Roggy is on a distinguished road
Unhappy Wiring piece between Sensor Plug and Control Board?
Model Number: B96070   Brand: Roper   Age: More than 10 years
I was getting an F3 Fault Code. I replaced the Sensor. I still get an F3 Fault Code. I replaced the Control Board. I still get an F3 Fault Code. I had a Service Tech come out and he found a part that he could not identify which he says is bad. There is a 3" wiring piece between the plug from the sensor and the Control Board. He says that there is no continuity from one end of the piece to the other. This piece has a 2-prong "female" plastic plug on one end (plugs into the lead coming from the Sensor) and a 3-prong "female" plastic plug on the other (plugs into the Contol Board - only 2 holes are used, the two outside holes). Inbetween the two plugs are two wires. One is a blue insulated wire and the other looks to be bare with an oversized insulation on it that reads "NE 105C L.T. 600 VW". I am assuming it may have been some type of resistor or something like that. This is the wire that doesn't have any continuity. The Service Tech can't identify it and it's not on the Parts Lists or Drawings. Does anyone know what it is and if so where can I find a new one??? Surely there's one somewhere. I'd hate to buy a new wall oven just because of this little part. HELP!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 07:08 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Arrow Looks like a fuse ...
According to your wiring diagram that is a fuse that opens at 102 degrees....not sure if you have to replace the wiring harness to obtain that fuse or not, will see what I can find.... CLICK HERE FOR WIRING DIAGRAM
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-03-2007, 07:22 PM
Pegi's Avatar
Senior Expert
APP Volunteer
Arrow Might do the trick...
This might, just might work in place of the fuse you now have in your range, this is for the Whirlpool ranges, Roper is made by Whirlpool, I cannot be responsable if this will not be right for your unit...
Part Details - WHIRLPOOL Fuse - thrml, part number: 9781691
__________________
  #4 (permalink)
Old 10-04-2007, 03:07 PM
Junior Member
Default
Thanks Pegi, but I don't think that will work. That piece looks like it has a ring lug on one end. And the piece I have has 2 wires with female plugs on both ends. One plug that plugs into the Sensor and the other plugs into the Control Board. Any other suggestions?????? Like I said..."Surely someone has one like this."
  #5 (permalink)
Old 10-04-2007, 06:08 PM
Pegi's Avatar
Senior Expert
APP Volunteer
Default
I do not, suspect the harness would have to be ordered, perhaps someone else will have a better suggestion...
__________________
  #6 (permalink)
Old 10-08-2007, 06:49 PM
Junior Member
Default
Still Waiting For Someone To Answer This Message That Knows How I Can Find This Part! I Thought This Was A Help Forum!?!?
  #7 (permalink)
Old 10-09-2007, 02:28 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Try pushing in on each connector pin, sometimes they get pushed out a little and fail to make contact. Also, you might try a non-residue spray combined with pushing the connectors together a few times.
__________________
  #8 (permalink)
Old 11-07-2007, 04:12 PM
Junior Member
Wink I Fixed It!!!
I fixed my problem!
It was the wiring piece that plugged in between the "Clock" and the Leads coming from the Sensor. One of the wires as I described between the plugs was a Thermal Resistor. I ordered one from Mousser Electronics and replaced it. I had to cut the old one out and the new one comes with crimp lugs. (Don't solder it or you'll blow the resistor again) I tried that. Good thing I ordered two. ($1.22 ea) I am beginning to think the problem started when we had the oven go through a "Self Clean". The high temperature must have blew the resistor. It has a different plug on each end so you can't wire/plug the sensor direct to the "Clock". You have to have this "WIRING PIECE" to connect the Sensor Leads to the Clock. The only problem I have now is the oven had a fan that turned on during use similar to a convection oven. Now the fan doesn't come on. It will if I turn the breaker off and back on but I have to push the "Cancel" button to get the fan to turn off and when I do it doesn't come back on when I push the "Bake" button to start the oven heating. My wife says it's OK if the fan doesn't work. The oven does now and we didn't have to buy a new one!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control board? rod Dishwasher Repair 1 11-05-2007 06:30 PM
Maytag control board replacement catsun54 Refrigerator & Freezer Repair 1 09-29-2007 02:55 AM
Control Board Installation Instructions tbj66 Refrigerator & Freezer Repair 3 09-11-2007 10:53 PM
Kitchenaid control board merceris Refrigerator & Freezer Repair 1 08-27-2007 09:36 AM
GE Profile Control Board ??? markham Oven Repair (including Ranges and Cooktops) 4 08-21-2007 04:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
