The ignitor was replaced and the oven's bake worked one time and then stopped working. The range top works, and the oven's broiler works, but the Bake will not work, Only reads 100 degrees but no heat is put out. I have been trying to find the wiring diagram with no luck. Can someone help me with this. 30" slide-in gas range Kenmore- 911.36755590,
