Discuss
Oven stopped igniting...need help!
 in
Hi. I'm new to the forum and I almost trashed the oven before trying to see if it could be
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven stopped igniting...need help!
  #1 (permalink)
Old 11-06-2008, 07:06 AM
Junior Member
myslyn is on a distinguished road
Question Oven stopped igniting...need help!
Model Number: 1197058810   Brand: Kenmore   Age: 5 - 10 years
Hi. I'm new to the forum and I almost trashed the oven before trying to see if it could be fixed.
The oven is a Kenmore 24 inch range that was in our home when we moved in about two years ago. It worked fine until earlier this year when it would not heat. Sometimes, it would heat up in time and I thought I would help it along by banging on the heating door...and it was amazing that the oven would ignite sometimes but now, it doesn't.
I see a small yellow-red flame in the back, and it only comes on if I turn on a top burner. The left side of the stove won't ignite without a match...I'm not sure what is going on or if it is something that can be fixed.
I have to have a stove this size because of space restraints so I'm inclined to try to fix it.
Any ideas?
Ads By Google
Related Models
Kenmore 119710630 KENMORE GAS RANGE
Kenmore 1197107000 KENMORE GAS RANGE
Kenmore 1197107020 KENMORE GAS RANGE
Kenmore 1197107040 KENMORE GAS RANGE
Kenmore 1197107060 KENMORE GAS RANGE
Kenmore 1197107210 KENMORE GAS RANGE
Kenmore 1197107220 KENMORE GAS RANGE
Kenmore 1197107240 KENMORE GAS RANGE
Kenmore 1197107260 KENMORE GAS RANGE
Kenmore 1197108310 KENMORE GAS RANGE
Kenmore 1197108311 KENMORE GAS RANGE
Kenmore 119711400 KENMORE GAS RANGE
Kenmore 119711440 KENMORE GAS RANGE
Kenmore 119711450 KENMORE GAS RANGE
Kenmore 119711460 KENMORE GAS RANGE
Kenmore 119711480 KENMORE GAS RANGE
Kenmore 119711500 KENMORE GAS RANGE
Kenmore 119711540 KENMORE GAS RANGE
Kenmore 119711550 KENMORE GAS RANGE
Kenmore 119711560 KENMORE GAS RANGE
Kenmore 119711580 KENMORE GAS RANGE
Kenmore 119711600 KENMORE GAS RANGE
Kenmore 1197116600 KENMORE GAS RANGE
Kenmore 1197116610 KENMORE GAS RANGE
Kenmore 1197116620 KENMORE GAS RANGE
Kenmore 1197116630 KENMORE GAS RANGE
Kenmore 1197116640 KENMORE GAS RANGE
Kenmore 1197118310 KENMORE GAS RANGE
Kenmore 1197118311 KENMORE GAS RANGE
Kenmore 119712400 KENMORE GAS RANGE
Kenmore 119712440 KENMORE GAS RANGE
Kenmore 119712450 KENMORE GAS RANGE
Kenmore 119712460 KENMORE GAS RANGE
Kenmore 119712480 KENMORE GAS RANGE
Kenmore 119712500 KENMORE GAS RANGE
Kenmore 119712540 KENMORE GAS RANGE
Kenmore 119712550 KENMORE GAS RANGE
Kenmore 119712560 KENMORE GAS RANGE
Kenmore 119712580 KENMORE GAS RANGE
Kenmore 119712600 KENMORE GAS RANGE
Kenmore 119712601 KENMORE GAS RANGE
Kenmore 1197126600 KENMORE GAS RANGE
Kenmore 1197126605 KENMORE GAS RANGE
Kenmore 1197126610 KENMORE GAS RANGE
Kenmore 1197126620 KENMORE GAS RANGE
Kenmore 1197126630 KENMORE GAS RANGE
Kenmore 1197126640 KENMORE GAS RANGE
Kenmore 119712850 KENMORE GAS RANGE
Kenmore 119712860 KENMORE GAS RANGE
Kenmore 119720600 KENMORE GAS RANGE
Kenmore 119720630 KENMORE GAS RANGE
Kenmore 119720640 KENMORE GAS RANGE
Kenmore 119720650 KENMORE GAS RANGE
Kenmore 1197206800 KENMORE GAS RANGE
Kenmore 1197207000 KENMORE GAS RANGE
Kenmore 1197207001 KENMORE GAS RANGE
Kenmore 1197207020 KENMORE GAS RANGE
Kenmore 1197207021 KENMORE GAS RANGE
Kenmore 1197207040 KENMORE GAS RANGE
Kenmore 1197207041 KENMORE GAS RANGE
Kenmore 1197207060 KENMORE GAS RANGE
Kenmore 1197207061 KENMORE GAS RANGE
Kenmore 119721400 KENMORE GAS RANGE
Kenmore 119721440 KENMORE GAS RANGE
Kenmore 119721460 KENMORE GAS RANGE
Kenmore 119721500 KENMORE GAS RANGE
Kenmore 119721600 KENMORE GAS RANGE
Kenmore 119721630 KENMORE GAS RANGE
Kenmore 119721660 KENMORE GAS RANGE
Kenmore 1197216600 KENMORE GAS RANGE
Kenmore 1197216610 KENMORE GAS RANGE
Kenmore 1197216620 KENMORE GAS RANGE
Kenmore 1197216700 KENMORE GAS RANGE
Kenmore 1197217310 KENMORE GAS RANGE
Kenmore 1197217311 KENMORE GAS RANGE
Kenmore 1197217312 KENMORE GAS RANGE
Kenmore 1197217320 KENMORE GAS RANGE
Kenmore 1197217321 KENMORE GAS RANGE
Kenmore 1197217322 KENMORE GAS RANGE
Kenmore 1197217340 KENMORE GAS RANGE
Kenmore 1197217341 KENMORE GAS RANGE
Kenmore 1197217342 KENMORE GAS RANGE
Kenmore 1197217360 KENMORE GAS RANGE
Kenmore 1197217361 KENMORE GAS RANGE
Kenmore 1197217362 KENMORE GAS RANGE
Kenmore 1197217410 KENMORE GAS RANGE
Kenmore 1197217411 KENMORE GAS RANGE
Kenmore 1197217420 KENMORE GAS RANGE
Kenmore 1197217421 KENMORE GAS RANGE
Kenmore 1197217440 KENMORE GAS RANGE
Kenmore 1197217441 KENMORE GAS RANGE
Kenmore 1197217460 KENMORE GAS RANGE
Kenmore 1197217461 KENMORE GAS RANGE
Kenmore 119722400 KENMORE GAS RANGE
Kenmore 119722450 KENMORE GAS RANGE
Kenmore 119722500 KENMORE GAS RANGE
Kenmore 119722600 KENMORE GAS RANGE
Kenmore 119722660 KENMORE GAS RANGE
Kenmore 119730630 KENMORE GAS RANGE
Kenmore 1197306700 KENMORE GAS RANGE
Kenmore 1197306730 KENMORE GAS RANGE
Kenmore 1197306740 KENMORE GAS RANGE
Kenmore 1197306760 KENMORE GAS RANGE
Kenmore 1197306790 KENMORE GAS RANGE
Kenmore 1197326800 KENMORE GAS RANGE
Kenmore 1197326840 KENMORE GAS RANGE
Kenmore 1197326860 KENMORE GAS RANGE
Kenmore 1197338311 KENMORE GAS RANGE
Kenmore 1197367311 KENMORE GAS RANGE
Kenmore 1197398311 KENMORE GAS RANGE
Kenmore 1197407000 KENMORE GAS RANGE
Kenmore 1197407020 KENMORE GAS RANGE
Kenmore 1197407040 KENMORE GAS RANGE
Kenmore 1197407210 KENMORE GAS RANGE
Kenmore 1197407211 KENMORE GAS RANGE
Kenmore 1197407220 KENMORE GAS RANGE
Kenmore 1197407221 KENMORE GAS RANGE
Kenmore 1197407240 KENMORE GAS RANGE
Kenmore 1197407241 KENMORE GAS RANGE
Kenmore 1197407260 KENMORE GAS RANGE
  #2 (permalink)
Old 11-06-2008, 04:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem with your oven is a bad igniter. Remove the oven floor and the flame spreader to access the igniter.
Does it click and spark on the left side burners of the stove when you turn a knob "on"?
If it does click and spark but does not light then lift up the top panel and, using a needle, unblock all holes on the burners.
- The part number for the oven igniter is AP2150412
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-08-2008, 09:00 AM
Junior Member
Default
Thanks Gene! I checked inside of the oven just like you told me and it is not igniting unless I turn a burner on, so I am ordering the part today.
I also cleaned out the burners like you mentioned and they are lighting better than before, so I am happy.
I'll be sure to follow-up on the install and thanks again!
  #4 (permalink)
Old 11-13-2008, 06:51 AM
Junior Member
Default Got oven ignitor...install help anyone please?
Hi.
I bought the part that Gene listed in his last post but I just want to be sure that I am installing it correctly.
There is a small bit of install instructions that came with the part but I was hoping someone might have something a bit more clearly defined. I'm not a repair person but I can follow instructions.
Thanks in advance for your help!
  #5 (permalink)
Old 11-13-2008, 08:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can find the complete instructions in one of our previous posts: Help - instructions to install oven igniter
__________________
  #6 (permalink)
Old 11-18-2008, 11:19 AM
Junior Member
Talking Thank you Appliance Repair forum for your help!
Hi all!
I just wanted to let you know that the information provided by this forum helped my husband and me fix the issues with our oven and THANKS to you, we will have a happy Thanksgiving! :-)
I'm going to tell as many people as I can about this wonderful place and thank you again for the help!
  #7 (permalink)
Old 11-18-2008, 01:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. We are glad you were able to fix it. Have a nice Holidays!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Oven not igniting confued Oven Repair (including Ranges and Cooktops) 0 12-18-2009 07:12 PM
Gas Oven Igniting but not staying lit SemarJ Oven Repair (including Ranges and Cooktops) 1 09-28-2009 08:53 AM
GE gas oven stopped igniting Archangel1469 Oven Repair (including Ranges and Cooktops) 4 07-27-2009 02:03 PM
Gas oven not igniting buggee Oven Repair (including Ranges and Cooktops) 1 07-22-2009 01:55 PM
Gas Oven NOT Igniting Ray Clow Oven Repair (including Ranges and Cooktops) 7 10-07-2008 03:10 PM
