| » Replacing top switch burner |
Model Number: csg7000cab Brand: Maytag Age: 5 - 10 years
I have a Maytag glass cook top (MN CSG7000CAB)and I am looking to swap out my rear top switch burner but I do not know how to get access to it. Are there any screws to remove to undo the glass top. Thanks in advance
Look in the cabinet it's installed in to see if it is anchored or clipped in. Do what you have to to remove the fasteners, if there are any. The unit will then come up out of the hole. The screws that hold the top to the body will then be visible. Be sure you unplug it and turn off the gas, before you remove the unit; and lay out towels or something to protect counter tops.
| Display Modes | |
| replaced stove top burner and infinite switch but burner still does not work | rcaple | Oven Repair (including Ranges and Cooktops) | 1 | 09-23-2010 05:34 PM |
| Replacing Maytag glass cootktop element does switch need replacing too? | rneumann1962 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2010 10:19 AM |
| Burner Switch | Mrozinski | Oven Repair (including Ranges and Cooktops) | 5 | 09-14-2009 08:12 PM |
| Burner Switch | Mrozinski | Oven Repair (including Ranges and Cooktops) | 0 | 09-13-2009 03:18 PM |
| Switch or burner bad | maytagproblems | Oven Repair (including Ranges and Cooktops) | 0 | 11-08-2008 07:03 AM |
