[FONT='Times New Roman','serif']I am trying to replace the ERC (clock assembly) on a Magic Chef Model 6498XTS slide in gas range. This appears to require removing the front panel above the oven that surrounds the knob and clock assembly. There are two screws that release the bottom of the panel, but the top is either hooked under or attached to the top of the stove. Would you please advise how to remove this panel so I can get to the clock assembly[/FONT] [FONT='Times New Roman','serif']Thank You[/FONT] [FONT='Times New Roman','serif']Bill two[/FONT]
