larry265
#1 Posted : Wednesday, November 10, 2010 9:55:57 AM(UTC)
larry265
Bake element didn't work, so bought new one. Went to change out discovered wire problem. took off rear panel & determined I needed new red bake element wire. Can I just splice in a new one with same gauge?
magician59
#2 Posted : Wednesday, November 10, 2010 11:19:25 AM(UTC)
magician59
Yes you can. Just make sure you use wire with the same heat rating, and be sure your splice stays outside the oven chamber.
Maytag Bake Element will not heat up (Oven Repair (including Ranges and Cooktops))
by Derswick 10/12/2009 2:26:52 PM(UTC)
Maytag bake element replacement problem (Oven Repair (including Ranges and Cooktops))
by kbiro 9/9/2008 10:59:08 AM(UTC)
