| » Hotpoint (GE) Gas Oven-Temperature changes |
Model Number: RGB745BEA3CT Brand: Hotpoint Age: 5 - 10 years
I have a Hotpoint gas oven (model RGB745BEA3CT) which I purchased new about 5 1/2 years ago. It seems to work okay at first. It usually reached the desired temperature. and stays there a little while. But then, even though the temperature dial hasn't been changed, my oven thermometer reports the temperature changes. Somtimes it goes up 100 degrees, sometimes it goes down. I thought that maybe it was the oven temperature sensor, but I replaced that, and I still have the same problem. Any suggestions? I need to take care of it asap, or my wife will not be too happy. Thanks Ads By Google Related Models |
Quote:
I do have an Ohm Meter. What is the bake glow bar, where is it, and which spot on the Bake Glow Bar should I test. Also, I assume you mean at room temperature. Is that correct? |
Quote:
You'll check it from the front, no need to pull the oven out. You should see a 2pin plastic connector down there, that's where you take your reading....Here's that part and picture for you....Part Details - GE Igniter, oven, part number: WB13K21
__________________
I just checked it. When I use the 10's category on my ohm meter, it comes to between 150 and 160. However, when I use the ones category, it comes to around 240- I tried it a few times, and this difference happens every time ( and yes, I have been switching the adjustment dial for each one to make sure it starts at zero). Does this mean that there is something wrong with my Multimeter?
| Display Modes | |
| HotPoint Oven | TGunter3@cfl.rr.com | Dishwasher Repair | 1 | 07-27-2009 04:01 PM |
| Hotpoint Oven is too hot | ggootee | Oven Repair (including Ranges and Cooktops) | 3 | 07-14-2009 02:22 PM |
| What size oven do I need to buy to replace a 70's hotpoint wall oven? | buckeye33 | Oven Repair (including Ranges and Cooktops) | 1 | 04-28-2009 08:42 AM |
| hotpoint gas oven | johril2@gmail.com | Oven Repair (including Ranges and Cooktops) | 0 | 12-30-2008 09:05 AM |
| Hotpoint Oven Temperature | ctbrown | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2008 04:02 PM |
