ge over & under oven wont heat used to click when setting temp now nothing think it is relay in control panel appears to be 3 relays can you replace them or do tou need whole control board ? .:cool:
I cannot find any info using the given model number. The following parts is for a similar model number but it does not have the "o" in it. Replacement parts for General Electric JKP27WW1WW Electric range | AppliancePartsPros.comUsually the board is replaced. The board (Item 16 in Section 1) shows only 2 element control relays but this board has been updated so perhaps they removed one relay. Relays must be sourced from electronics suppliers and finding them is a pain. Also troubleshooting them is difficult for most DIYers. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman I cannot find any info using the given model number. The following parts is for a similar model number but it does not have the "o" in it. Replacement parts for General Electric JKP27WW1WW Electric range | AppliancePartsPros.comUsually the board is replaced. The board (Item 16 in Section 1) shows only 2 element control relays but this board has been updated so perhaps they removed one relay. Relays must be sourced from electronics suppliers and finding them is a pain. Also troubleshooting them is difficult for most DIYers. Thanks for Info ILL try control board found #2 relay open when voltage supplyed to it ie burnt contacts.
