Discuss
Bluetruck22
 in
Oven temp won't work right. It will heat to 350 degrees when set at 450. I have replaced the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bluetruck22
  #1 (permalink)
Old 11-09-2010, 03:46 PM
Junior Member
Bluetruck22 is on a distinguished road
Default Bluetruck22
Model Number: CRE9600ACW   Brand: Maytag   Age: More than 10 years
Oven temp won't work right. It will heat to 350 degrees when set at 450. I have replaced the oven sensor, can you tell me what could be the problem. My email is rllakins@musfiber.com
Related Models
Maytag CRE9600ACW RANGE- S/C F/S ELE
Maytag CRE9600ADE RANGE- S/C F/S ELE
Maytag CRE9600ADL RANGE- S/C F/S ELE
Maytag CRE9600ADW RANGE- S/C F/S ELE
Maytag CRE9600BCE RANGE- S/C F/S ELE
Maytag CRE9600BCL RANGE- S/C F/S ELE
Maytag CRE9600BCW RANGE- S/C F/S ELE
Maytag CRE9600CCE RANGE- S/C F/S ELE
Maytag CRE9600CCM RANGE- S/C F/S ELE
Maytag CRE9600CDE RANGE- S/C F/S ELE
Maytag CRE9600CDL RANGE- S/C F/S ELE
Maytag CRE9600CDW RANGE- S/C F/S ELE
Admiral CRE9600CGE RANGE- S/C F/S ELE
Maytag CRE9600DDE RANGE- S/C F/S ELE
Maytag CRE9600DDM RANGE- S/C F/S ELE
Maytag CRE9700ACB RANGE- S/C F/S ELE
Maytag CRE9700ACE RANGE- S/C F/S ELE
Maytag CRE9700ADB RANGE- S/C F/S ELE
Maytag CRE9700ADE RANGE- S/C F/S ELE
Maytag CRE9800ACB RANGE- S/C F/S ELE
Maytag CRE9800ACE RANGE- S/C F/S ELE
Maytag CRE9800ADB RANGE- S/C F/S ELE
Maytag CRE9800ADE RANGE- S/C F/S ELE
Maytag CRE9800BCB RANGE- S/C F/S ELE
Maytag CRE9800BCE RANGE- S/C F/S ELE
Maytag CRE9800CCB RANGE- S/C F/S ELE
Maytag CRE9800CCE RANGE- S/C F/S ELE
Maytag CRE9800CCM RANGE- S/C F/S ELE
Maytag CRE9800CDB RANGE- S/C F/S ELE
Maytag CRE9800CDE RANGE- S/C F/S ELE
Maytag CRE9800DDB RANGE- S/C F/S ELE
Maytag CRE9800DDE RANGE- S/C F/S ELE
Maytag CRE9800DDM RANGE- S/C F/S ELE
Maytag CRE9830BCB RANGE- S/C F/S ELE
Maytag CRE9830BCE RANGE- S/C F/S ELE
Maytag CRE9830BCM RANGE- S/C F/S ELE
Maytag CRE9830CDB RANGE- S/C F/S ELE
Maytag CRE9830CDE RANGE- S/C F/S ELE
Maytag CRE9830CDM RANGE- S/C F/S ELE
Maytag CRE9900ACB RANGE- S/C F/S ELE
Maytag CRE9900ACE RANGE- S/C F/S ELE
Admiral CREA200ACL RANGE- F/S STD ELE
Admiral CREA200ACW RANGE- F/S STD ELE
Admiral CREA300ACL RANGE- F/S STD ELE
Admiral CREA300ACW RANGE- F/S STD ELE
Admiral CREA400ACL RANGE- F/S STD ELE
Admiral CREA400ACW RANGE- F/S STD ELE
Admiral CREA450ACL RANGE- F/S STD ELE
Admiral CREA450ACW RANGE- F/S STD ELE
Admiral CREA600ACE RANGE- S/C F/S ELE
Admiral CREA600ACL RANGE- S/C F/S ELE
Admiral CREA600ACW RANGE- S/C F/S ELE
Admiral CREA650ACB RANGE- S/C F/S ELE
Admiral CREA650ACL RANGE- S/C F/S ELE
Admiral CREA650ACW RANGE- S/C F/S ELE
Admiral CREA750ACB RANGE- S/C F/S ELE
Admiral CREA750ACE RANGE- S/C F/S ELE
Admiral CREA750ACM RANGE- S/C F/S ELE
Frigidaire CREF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CREF342AS1 Dryer - Frig/best Buy
Frigidaire CREF342AS2 Frigidaire/electric Dryer
Crosley CREF366FBA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FCA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FSA BRADA CANADA/ELECTRIC RANGE
Frigidaire CRER442AS0 Dryer - Frig/best Buy
Frigidaire CRER442AS1 Dryer - Frig/best Buy
Frigidaire CRER442AS2 Dryer - Frig/best Buy
Frigidaire CRER5700AS0 Dryer - Frig/best Buy
Frigidaire CRER5700AS1 Frigidaire/electric Dryer
Frigidaire CRER7900AS0 Dryer - Frig/best Buy
Frigidaire CRER7900AS1 Frigidaire/electric Dryer
Maytag CRG0560AAW Range - F/s Std Gas
Maytag CRG0760AAL RANGE- S/C F/S GAS
Maytag CRG0760AAW RANGE- S/C F/S GAS
Maytag CRG0860AAL RANGE- S/C F/S GAS
Maytag CRG0860AAW RANGE- S/C F/S GAS
Maytag CRG200 RANGE- F/S STD GAS
Maytag CRG200B RANGE- F/S STD GAS
Maytag CRG300 RANGE- F/S STD GAS
Maytag CRG300B RANGE- F/S STD GAS
Maytag CRG305 RANGE- F/S STD GAS
Maytag CRG350 RANGE- F/S STD GAS
Maytag CRG350B RANGE- F/S STD GAS
Maytag CRG355 RANGE- F/S STD GAS
Maytag CRG382 RANGE- F/S STD GAS
Maytag CRG383 RANGE- F/S STD GAS
Maytag CRG400 RANGE- F/S STD GAS
Maytag CRG400B RANGE- F/S STD GAS
Maytag CRG405 RANGE-F/S CONT CLEAN GAS
Maytag CRG500 RANGE- F/S STD GAS
Maytag CRG501 RANGE- F/S STD GAS
Maytag CRG502 RANGE- F/S STD GAS
Maytag CRG505 RANGE- F/S STD GAS
Maytag CRG560 RANGE- F/S STD GAS
Maytag CRG560A RANGE- F/S STD GAS
Maytag CRG583 RANGE-F/S CONT CLEAN GAS
Maytag CRG600 RANGE- F/S STD GAS
Maytag CRG601 RANGE- F/S STD GAS
Maytag CRG602 RANGE-F/S CONT CLEAN GAS
Maytag CRG700 RANGE- S/C F/S GAS
Maytag CRG705 RANGE- S/C F/S GAS
Maytag CRG7400AAL RANGE- F/S STD GAS
Maytag CRG7400AAW RANGE- F/S STD GAS
Maytag CRG7400BAL RANGE- F/S STD GAS
Maytag CRG7400BAW RANGE- F/S STD GAS
Maytag CRG7400CAE RANGE- F/S STD GAS
Maytag CRG7400CAL RANGE- F/S STD GAS
Maytag CRG7400CAW RANGE- F/S STD GAS
Maytag CRG750 RANGE- S/C F/S GAS
Maytag CRG7500AAE RANGE- F/S STD GAS
Maytag CRG7500AAL RANGE- F/S STD GAS
Maytag CRG7500AAW RANGE- F/S STD GAS
Maytag CRG7500CAE RANGE- F/S STD GAS
Maytag CRG7500CAL RANGE- F/S STD GAS
Maytag CRG7500CAW RANGE- F/S STD GAS
Admiral CRG7500CGE RANGE- F/S STD GAS
Admiral CRG7500CGW RANGE- F/S STD GAS
Maytag CRG755 RANGE- S/C F/S GAS
Maytag CRG760 RANGE- S/C F/S GAS
Maytag CRG7600AAL RANGE-F/S CONT CLEAN GAS
  #2 (permalink)
Old 11-10-2010, 03:24 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Do both elements work?
Could be one of them is burned out.
Often during preheat units either use both elements or switch back and forth between the two elements.
Also often once an oven reaches set point the elements are switched back and forth. This gives a more even heat gradient in the oven.
__________________
  #3 (permalink)
Old 11-10-2010, 05:43 AM
Junior Member
Default Bluetruck22
Both Elements do work. Only the bottom element when in preheat. Top element only works broil mode.
  #4 (permalink)
Old 11-10-2010, 06:00 AM
Senior Expert
APP Volunteer
Default
Here are the parts
Replacement parts for MAYTAG CRE9600ACW Range - S/c F/s Ele | AppliancePartsPros.com
Since both elements work, and everything looks normal and you have replaced the sensor, all that I can think of is that your control board (item 14 in Section 2) is shot.
I am assuming that you have at one point removed power from the unit and reconnected it and the problem was still there (computer did a reset).
Also that when the elements do come on, they do get red (you have 240 volts).
Since you have done some troubleshooting, if you order the board from AppliancePartsPros and it does not fix your problem you can return it. Please see their return policy.
Note: That I do not work for AppliancePartsPros.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
