Discuss
Oven doesn't work, but stove does, different from others
 in
Well the other day my wife says that the oven does not work. I turned it on and nothing. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doesn't work, but stove does, different from others
  #1 (permalink)
Old 11-07-2010, 07:09 PM
Junior Member
J57ltr is on a distinguished road
Default Oven doesn't work, but stove does, different from others
Model Number: SF110AXSQ0   Brand: Whirlpool   Age: 1 - 5 years
Well the other day my wife says that the oven does not work. I turned it on and nothing. I know before that I would see the ignighter glow through the vents on the sides of the stove, then I would hear the gas turn on and I could hear the whoosh as the gas lit. Now you turn the knob and nothing happens.
Here is what I checked so far:
I checked the valve at the back and seemed to have 120VAC at the terminals of the safety valve. I disconnected the igniter and checked it's resistance and it showed 15.5 MegaOhms, it does not change when I tap it. I am not sure what it should read.
The igniter is this one:
Part Details - WHIRLPOOL Ignitor, oven, part number: AP3129373
Safety valve:
Part Details - WHIRLPOOL Valve, gas, part number: AP3711295
The Safety valve seemed to not be working. Looking at the schematic and wiring. The igniter is wired in series with the safety valve. I am guessing now that the resistance of the igniter keeps the current low enough that it keeps the voltage low enough to not damage the valve.
I did not check the resistance on the terminals of the valve, and I am pretty sure I burned it out. I removed the igniter connector and jumped the connector out. I turned on the oven and lit it with a BBQ lighter. it came on and the burner lit but went out after about 5 seconds. In hindsight this looks like I made about a hundred dollar mistake. I checked the resistance and it's open.
My questions are:
I am guessing the igniter was bad, but what do the experts think?
What should the resistance of the igniter be?
Is there another (cheaper) valve that can be substituted? (if I did take it out)
If the igniter and the Valve were good to begin with what else could have caused the stove not to work?
Thanks for any help.
Jeff
Related Models
Whirlpool SF110AXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF110AXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF110AXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSB1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSB2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXST0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXST1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXST2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSW0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSW1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF114PXSW2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF195LEHQ0 GAS RANGE
Whirlpool SF195LEHQ5 GAS RANGE
Whirlpool SF195LEHQ6 GAS RANGE
Whirlpool SF195LEHT5 GAS RANGE
Whirlpool SF195LEHT6 GAS RANGE
Whirlpool SF195LEHZ0 GAS RANGE
Whirlpool SF195LEHZ5 GAS RANGE
Whirlpool SF195LEKB0 GAS RANGE
Whirlpool SF195LEKB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURN
Whirlpool SF195LEKQ0 GAS RANGE
Whirlpool SF195LEKQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURN
Whirlpool SF195LEKT0 GAS RANGE
Whirlpool SF195LEKT1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURN
Whirlpool SF196LEMB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEMB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEMQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEMQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEMT0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEMT1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPB3 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPQ2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPQ3 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPT0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPT1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPT2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF196LEPT3 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF197LEHQ7 FREE STANDING, GAS
Whirlpool SF197LEHT7 FREE STANDING, GAS
Whirlpool SF197LEHZ7 FREE STANDING, GAS
Whirlpool SF216LXSM0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF216LXSM1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF216LXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF216LXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF262LXSB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXSB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXSQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXSQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXST0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXST1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXSW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF262LXSW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTQ2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTT0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTT1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF265LXTT2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool SF272LXTD0 30" GAS FREESTANDING SELF CLEAN RANGE
Whirlpool SF272LXTD1 30" GAS FREESTANDING SELF CLEAN RANGE
Whirlpool SF272LXTD2 30" GAS FREESTANDING SELF CLEAN RANGE
Whirlpool SF3000EKW0 Range (gas)*
Whirlpool SF3000EPW0 Range (gas)*
Whirlpool SF3000ERN6 GAS RANGE
Whirlpool SF3000ERW0 Range (gas)*
Whirlpool SF3000ERW1 Range (gas)*
Whirlpool SF3000ERW2 Range (gas)*
Whirlpool SF3000ERW3 Range (gas)*
Whirlpool SF3000ERW4 Range (gas)*
Whirlpool SF3000ERW5 Range (gas)*
Whirlpool SF3000ERW6 GAS RANGE
Whirlpool SF3000EWW0 Range (gas)*
Whirlpool SF3000EWW1 Range (gas)*
Whirlpool SF3000EYN0
Whirlpool SF3000EYN2 30" GAS FREESTANDING RANGE STANDARD CLEAN OVEN
Whirlpool SF3000EYN3 30" GAS FREESTANDING RANGE
Whirlpool SF3000EYN4 30" GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF3000EYN5 30" GAS FREESTANDING RANGE
Whirlpool SF3000EYW0 Range (gas)*
Whirlpool SF3000EYW1 Range (gas)*
Whirlpool SF3000EYW2 30" GAS FREESTANDING RANGE STANDARD CLEAN OVEN
Whirlpool SF3000EYW3 30" GAS FREESTANDING RANGE
Whirlpool SF3000EYW4 30" GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF3000EYW5 30" GAS FREESTANDING RANGE
Whirlpool SF3000SEN0 30" FREESTANDING GAS RANGE
Whirlpool SF3000SEW0 30" FREESTANDING GAS RANGE
Whirlpool SF3000SGN0 30" GAS RANGE
Whirlpool SF3000SGN1 GAS FREESTANDING RANGE
Whirlpool SF3000SGW0 30" GAS RANGE
Whirlpool SF3000SGW1 GAS FREESTANDING RANGE
Whirlpool SF3000SKW0 Range (gas)*
Whirlpool SF3000SRN6 30" GAS FREESTANDING RANGE
Whirlpool SF3000SRW0 GAS RANGE
Whirlpool SF3000SRW1 Range (gas)*
Whirlpool SF3000SRW2 Range (gas)*
Whirlpool SF3000SRW3 Range (gas)*
Whirlpool SF3000SRW4 Range (gas)*
Whirlpool SF3000SRW5 Range (gas)*
Whirlpool SF3000SRW6 30" GAS FREESTANDING RANGE
Whirlpool SF3000SWW1 Range (gas)*
Whirlpool SF3000SYN0
Whirlpool SF3000SYN2 30" GAS FREESTANDING RANGE
  #2 (permalink)
Old 11-08-2010, 05:44 PM
Junior Member
Default
Could really use some help on this. Speaking with the Appliance repair store they were unable to tell me what the resistance of the igniter is they say if they suspect that it is bad they replace it. To me this is not trouble shooting it's parts replacing and that is a not what I am about.
I have taken the oven apart and there are no other componets that would drop the voltage to keep from damaging the safety valve so the igniter must be the only thing. I really need to know what the value should be so I can I can tell if it is out of range and order the parts. I would like to order the parts and get it fixed by this weekend.
Jeff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven doesn't work - Stove fine ajcannella Oven Repair (including Ranges and Cooktops) 5 09-06-2011 09:08 AM
Main oven does not heat but the stove top and the bottom oven work wes2ii Oven Repair (including Ranges and Cooktops) 5 09-23-2010 02:22 PM
Electric Range Oven and Stove do not work mcki272 Oven Repair (including Ranges and Cooktops) 1 10-16-2009 11:49 AM
Control panel and oven won't work but stove does Gore70 Oven Repair (including Ranges and Cooktops) 1 11-23-2008 06:35 AM
bROILER AND STOVE WORK BUT NOT OVEN aburns24 Oven Repair (including Ranges and Cooktops) 2 11-20-2008 05:48 PM
