Have an ignitor issue. The model is just barely over 1 yr old & was in a rental home. Tenant moved out & I discovered a gas leak on the front right supply tube & replaced & repaired, but the electrode will not ignite when turning the knob. It does not click- so therefore no spark. The electrode & wiring look find as do the other 3 burners as well as the grounding. All 3 other burners work fine and if you turn on any of the other 3- it also sparks the defective burner and it will fire up if you turn gas on at the same time. But it just won't ignite itself. Any ideas or suggestions would be great. Thanks P.S. This model # is correct, but no online or local store seems to locate that exact model ending in 3ww...?
