Discuss
Gas Build up
 in
I have a Dacor RSG30 and when I use the oven I can sometimes smell gas - when I open the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Build up
  #1 (permalink)
Old 10-02-2007, 08:12 AM
Katydog Katydog is offline
Junior Member
Katydog is on a distinguished road
Default Gas Build up
Model Number: RSG30   Brand: Dacor   Age: 5 - 10 years
I have a Dacor RSG30 and when I use the oven I can sometimes smell gas - when I open the door I get a whoosh of gas/flame (like a back draft) - this does this on both regular oven use and convection.
I was told it was probably a faulty gas valve as I do not smell gas when the oven is not in use..
Any thoughts?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 11:16 PM
bjv bjv is offline
Junior Member
bjv is on a distinguished road
Default
if this range has gas broiler it is use during pre heat and would but your problem is delayed ignition of broiler when you open oven door you are pulling gas threw broiler tiles and its igniting chech to see if the broil ignitor is generating 3.5 amps if its only showing 2.9 to 3.2 the safty valve vill still open but will not let prorer gas flow in that case i would shange ignitor and its a lot cheeper than the saftey valve hope this helps
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice build up in the bottom of the freezer lauder Refrigerator & Freezer Repair 1 08-22-2007 08:53 PM
Fridge Cabinet Ice Build-up M Groves Refrigerator & Freezer Repair 0 08-22-2007 05:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
