| » Clock dead, no oven controls, burners barely glow |
Model Number: ART6511WW Brand: Amana Age: 5 - 10 years
It seems to not be getting enough power. Just moved to an old house. The 3 prong plug was used at the last new home we were in. The breaker is 50 amps and the wire has an orange casing. What is the problem?
I would first measure voltage into the stove while everything is turned on. If voltage way below 230 volts, you probably have a burnt wire in the wall outlet, or a burnt wire inside the house fuse box. Good voltage at stove connector means you have a burnt wire in the stove.
__________________
| Display Modes | |
| Oven & broiler igniters do not glow | terrapin | Oven Repair (including Ranges and Cooktops) | 0 | 09-28-2007 10:23 AM |
| Range/Oven/Clock Don't Work | Merlyn | Oven Repair (including Ranges and Cooktops) | 0 | 09-22-2007 10:21 PM |
| Oven Controls Completly out | RCrom | Oven Repair (including Ranges and Cooktops) | 0 | 09-20-2007 07:51 PM |
| stove top works/clock on/oven controls dead | jrob | Oven Repair (including Ranges and Cooktops) | 4 | 09-20-2007 10:31 AM |
| Burners and oven will not ignite | bren | Oven Repair (including Ranges and Cooktops) | 2 | 08-09-2007 01:15 PM |
