Discuss
How do i Open the Glass top to replace a burner element
 in
I need to replace the heating coil/burner on the front right (large) and we cannot find how to open the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How do i Open the Glass top to replace a burner element
  #1 (permalink)
Old 11-05-2010, 08:25 AM
Junior Member
Beverly h is on a distinguished road
Default How do i Open the Glass top to replace a burner element
Model Number: LER333OAAZ   Brand: Admiral   Age: 5 - 10 years
I need to replace the heating coil/burner on the front right (large) and we cannot find how to open the glass top lid to get to it.
Any help is appreciated!
Related Models
Whirlpool LER3422AW0 Residential Dryer
Whirlpool LER3424AW0 Residential Dryer
Whirlpool LER3622BN0 COMPACT ELECTRIC DRYER
Whirlpool LER3622BW0 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622HQ0 DRYER
Whirlpool LER3622HQ1 RESIDENTIAL DRYER
Whirlpool LER3622PQ0 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3624BN2 ELECTRIC DRYER
Whirlpool LER3624BN3 ELECTRIC DRYER
Whirlpool LER3624BW0 ELECTRIC DRYER
Whirlpool LER3624BW1 ELECTRIC DRYER
Whirlpool LER3624BW2 ELECTRIC DRYER
Whirlpool LER3624BW3 ELECTRIC DRYER
Whirlpool LER3624DQ0 DRYER
Whirlpool LER3624DQ1 ELECTRIC DRYER
Whirlpool LER3624DQ2 ELECTRIC DRYER
Whirlpool LER3624DZ0 DRYER
Whirlpool LER3624DZ2 ELECTRIC DRYER
Whirlpool LER3624EQ0 LAUNDRY DRYERS
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
  #2 (permalink)
Old 11-05-2010, 09:59 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Beverly,
First, are you sure the burner is bad ?
The burner switch failure is more common than a bad burner.
To raise the cooktop,
Of course turn off the power to the range, or unplug the power cord, First.
Open or remove the oven door.
You should find a 1/4 inch screw at each end of the black metal oven top flange, remove those two screws.
You can then raise the front of the cook top and remove it.
When you replace the burner, double check and make sure you match the wire terminal label for terminal label( 1a to 1a, 2a to 2a etc.) some of the terminals on new replacement parts are not in the same location as original parts.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-06-2010, 05:07 AM
Junior Member
Default Hmmm
Im pretty sur eit is..when the burner is lit.. you cna see the red glow under the glass top and you can see the one swirl of coil that stays black and is burnt out
  #4 (permalink)
Old 11-08-2010, 08:50 AM
Senior Expert
Default
Beverly,
OK,
Thanks for the update, it helped.
It does sound like a damaged element, but I still hope it's a broke or loose wire.
Like I said, a bad element is not all that common,
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I open the glass cook top to replace an element? wd8iou Oven Repair (including Ranges and Cooktops) 0 03-26-2010 10:30 AM
how to replace a burner on a kenmore glass top djfoxylady Oven Repair (including Ranges and Cooktops) 0 10-23-2009 07:51 AM
How to replace glass top element lananana Oven Repair (including Ranges and Cooktops) 0 07-09-2008 04:09 PM
Replacing a glass top burner element billy_mc Oven Repair (including Ranges and Cooktops) 1 06-15-2008 08:11 PM
How to replace burner element Bob M Oven Repair (including Ranges and Cooktops) 1 03-10-2008 08:57 AM
