Discuss
Oven temperature never gets above 199 degrees
 in
Subject stove temperature reaches 199 degrees, then display goes blank. Oven sensor indicates 1.1 K ohm. I assume the ERC
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temperature never gets above 199 degrees
  #1 (permalink)
Old 11-01-2008, 05:37 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default Oven temperature never gets above 199 degrees
Model Number: ARDS800E   Brand: Amana   Age: 5 - 10 years
Subject stove temperature reaches 199 degrees, then display goes blank. Oven sensor indicates 1.1 K ohm. I assume the ERC is bad. This is mounted just above the oven door which I assume helped it fail due to the exposure to heat.
Any input appreciated.
Related Models
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
Amana ARDS802SS RANGE- S/C S/I DDRAFT ELE
Amana ARDS802WW RANGE- S/C S/I DDRAFT ELE
Amana ARE14 MISC / ACCESSORY
Amana ARE640 RANGE- S/C S/I DDRAFT GAS
Amana ARE640 RANGE- S/C S/I DDRAFT ELE
Amana ARE650 RANGE- S/C S/I DDRAFT GAS
Amana ARE650 RANGE- S/C S/I DDRAFT ELE
Amana ARG3600L RANGE- S/C S/I DDRAFT GAS
Amana ARG3600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3600W RANGE- S/C S/I DDRAFT GAS
Amana ARG3600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG3601L RANGE- S/C S/I DDRAFT GAS
Amana ARG3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3601W RANGE- S/C S/I DDRAFT GAS
Amana ARG3601WW RANGE- S/C S/I DDRAFT GAS
Whirlpool ARG483WP01 Refrigerators*
Whirlpool ARG490 REFRIGERATOR
Whirlpool ARG4901 SIDE-BY-SIDE REFRIGERATOR
Amana ARG7102C RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C F/S GAS
Amana ARG7102L Range - S/c S/i Ddraft Gas
Amana ARG7102W RANGE- S/C F/S GAS
Amana ARG7102W RANGE- S/C S/I DDRAFT GAS
Amana ARG7200L RANGE- S/C S/I DDRAFT GAS
Amana ARG7200W RANGE- S/C S/I DDRAFT GAS
Amana ARG7202 E RANGE- S/C S/I DDRAFT GAS
Amana ARG7300LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7300W RANGE- S/C S/I DDRAFT GAS
Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7301L RANGE- S/C S/I DDRAFT GAS
Amana ARG7301LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7301W RANGE- S/C S/I DDRAFT GAS
Amana ARG7301WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7302CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7302LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7302WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7303CC RANGE- S/C F/S GAS
Amana ARG7303LL RANGE- S/C F/S GAS
Amana ARG7303WW RANGE- S/C F/S GAS
Amana ARG7600CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C F/S GAS
Amana ARG7600LL RANGE- S/C S/I DDRAFT GAS
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer Temperature 11 and 44 Degrees redbluffkid Refrigerator & Freezer Repair 0 02-09-2010 09:36 AM
Oven won't go over 250 degrees westillustration Oven Repair (including Ranges and Cooktops) 3 11-05-2009 09:32 AM
Oven temperature of 25 degrees carolr Oven Repair (including Ranges and Cooktops) 3 01-18-2009 08:44 AM
Temperature not where display says (at least 75-100 degrees below) SidCharming Oven Repair (including Ranges and Cooktops) 1 01-04-2009 06:48 PM
oven temperature varies 100 degrees bigal_1234@msn.com Oven Repair (including Ranges and Cooktops) 2 01-31-2008 04:09 PM
