Discuss
Thermador Downdraft Gasket Problem
 in
We have a Thermador Cook N Vent UCV30AS (purchased in 2006) which works in all respects except we are having
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Downdraft Gasket Problem
  #1 (permalink)
Old 11-01-2010, 08:15 AM
Junior Member
SSilverman is on a distinguished road
Default Thermador Downdraft Gasket Problem
Model Number: UCV30AS   Brand: Thermador   Age: 1 - 5 years
We have a Thermador Cook N Vent UCV30AS (purchased in 2006) which works in all respects except we are having a problem with the gasket at the base of the snorkel. When raising the snorkel, the gray gasket becomes disengaged and gets pushed out. This happens on the left side in particular. I then need to work the gasket back into place which is quite a task.
Is there any known solution to this problem.
Thank you.
-Scott
Ads By Google
Related Models
Magic Chef UD158 Dishwasher - Undercounter
Magic Chef UD158-1 Dishwasher - Undercounter
Magic Chef UD258 Dishwasher - Undercounter
Magic Chef UD258-1 Dishwasher - Undercounter
Magic Chef UD358 Dishwasher - Undercounter
Magic Chef UD358-1 Dishwasher - Undercounter
Magic Chef UD458 Dishwasher - Undercounter
Magic Chef UD458-1 Dishwasher - Undercounter
Amana UDS30E Commercial Microwaves
Menu Master UDS30E  Commercial Microwaves
Menu Master UDS30E2  Commercial Microwaves
Amana UE8031 Washer - Top Loading
Amana UE8230 Washer - Top Loading
Frigidaire UF10FL1 Frg(v1) / Upright Freezer
Frigidaire UF10FL2 Frg(v2) / Upright Freezer
Frigidaire UF10FL3 Frg(v3) / Upright Freezer
Frigidaire UF10NL1 Frg(v1) / Upright Freezer
Frigidaire UF10NL2 Frg(v1) / Upright Freezer
Frigidaire UF1141CA8 Wwh(v1) / Upright Freezer
Amana UF12K Freezer - Vertical
Amana UF12K-A Freezer - Vertical
Amana UF12K-AG Freezer - Vertical
Amana UF12K-C Freezer - Vertical
Amana UF12W Freezer - Vertical
Amana UF12W-A Freezer - Vertical
Amana UF12W-AG Freezer - Vertical
Amana UF12W-C Freezer - Vertical
Admiral UF130 Freezer - Vertical
Frigidaire UF13DL1 Frg(v1) / Upright Freezer
Frigidaire UF13DL2 Frg(v1) / Upright Freezer
Frigidaire UF13DL3 Frg(v2) / Upright Freezer
Frigidaire UF13DL4 Frg(v3) / Upright Freezer
Frigidaire UF13DL5 Frg(v1) / Upright Freezer
Frigidaire UF13DL6 Frg(v3) / Upright Freezer
Frigidaire UF13FL1 Frg(v1) / Upright Freezer
Frigidaire UF13FL2 Frg(v2) / Upright Freezer
Frigidaire UF13FL3 Frg(v3) / Upright Freezer
Frigidaire UF13JW5 Frg(v1) / Upright Freezer
Frigidaire UF13JW6 Frg(v2) / Upright Freezer
Amana UF13K-A Freezer - Vertical
Frigidaire UF13NL1 Frg(v1) / Upright Freezer
Frigidaire UF13NL2 Frg(v1) / Upright Freezer
Frigidaire UF1463CA7 Wwh(v2) / Upright Freezer
Amana UF16 Freezer - Vertical
Amana UF16-A Freezer - Vertical
Amana UF16-C Freezer - Vertical
Frigidaire UF1647CW9 Wwh(v3) / Upright Freezer
Amana UF16A Freezer - Vertical
Amana UF16AG Freezer - Vertical
Amana UF16C Freezer - Vertical
Frigidaire UF16DL1 Frg(v2) / Upright Freezer
Frigidaire UF16DL2 Frg(v4) / Upright Freezer
Frigidaire UF16DL3 Frg(v1) / Upright Freezer
Frigidaire UF16DL4 Frg(v2) / Upright Freezer
Amana UF16F Freezer - Vertical
Amana UF16F-A Freezer - Vertical
Amana UF16F-C Freezer - Vertical
Amana UF16K Freezer - Vertical
Amana UF16K-A Freezer - Vertical
Amana UF16K-AG Freezer - Vertical
Amana UF16K-C Freezer - Vertical
Frigidaire UF16NL1 Frg(v1) / Upright Freezer
Frigidaire UF16NL2 Frg(v1) / Upright Freezer
Frigidaire UF16NL4 Frg(v1) / Upright Freezer
Amana UF16W Freezer - Vertical
Amana UF16W-A Freezer - Vertical
Amana UF16W-AG Freezer - Vertical
Amana UF16W-C Freezer - Vertical
Admiral UF180 Freezer - Vertical
Frigidaire UF2075CW7
Frigidaire UF2099DW2
Admiral UF210 Freezer - Vertical
Frigidaire UF2164CW8
Frigidaire UF21DL1 Frg(v3) / Upright Freezer
Frigidaire UF21DL2 Frg(v5) / Upright Freezer
Frigidaire UF21DL3 Frg(v1) / Upright Freezer
Frigidaire UF21DL4 Frg(v2) / Upright Freezer
Frigidaire UF21NL1 Frg(v1) / Upright Freezer
Frigidaire UF21NL2 Frg(v1) / Upright Freezer
Frigidaire UF21NL4 Frg(v1) / Upright Freezer
Amana UF22B Freezer - Vertical
Amana UF22B-A Freezer - Vertical
Amana UF22B-AG Freezer - Vertical
Amana UF22B-C Freezer - Vertical
Amana UF22B-L Freezer - Vertical
Amana UF22C Freezer - Vertical
Amana UF22K Freezer - Vertical
Amana UF22K-A Freezer - Vertical
Amana UF22K-AG Freezer - Vertical
Amana UF22K-C Freezer - Vertical
  #2 (permalink)
Old 01-30-2012, 11:49 AM
Junior Member
Rocketjon is on a distinguished road
Default Gasket repair
I posted this solution on fixya.com but I'll summarize it here. I have a Thermadoor cooktop mounted in front of the vent unit. I pulled out the old gray gasket and replaced it with a piece of Q-Lon door weatherstrip (try Home Depot ,etc., or it can be found at Amazon.) Loosen the screws under the cooktop that hold it down and slide the weatherstrip mounting flange under the cooktop and tighten the screws. You may have to give the snorkel a push to get it to go down since the weatherstrip pushes on it and there is a sensor that stops the snorkel if there is binding. I don't find this to be a problem and with time and some lubrication on the vent it may work without help. Contact me if you have any questions. jon@harrison.net
I have a 36" wide vent and I cut the weatherstrip 32 3/4" long
Jon
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Weird Bosch Downdraft Problem spookygeek Oven Repair (including Ranges and Cooktops) 0 08-03-2010 06:35 AM
Jenn-Air downdraft problem barmstrong@aarons-inc.com Oven Repair (including Ranges and Cooktops) 1 03-17-2010 02:20 PM
Thermador Downdraft Opinion Please mongome Oven Repair (including Ranges and Cooktops) 4 02-16-2009 06:23 PM
thermador downdraft was struggling, now mostly dead blakekr Oven Repair (including Ranges and Cooktops) 0 02-10-2009 09:07 PM
downdraft blower up/down problem hance Oven Repair (including Ranges and Cooktops) 1 12-26-2008 05:58 PM
