| » Oven is burning everything! |
A model number may help others help you.
What are my chances of being be able to recalibrate the thermastat? Chances are 0. On most units the most you can recalibrate is plus/minus 35 degrees. Yours sounds way out. Will I have to replace the control unit? Too early to tell you need to do some troubleshooting. Should I start shopping for a new one (Not in the budget)? Not yet. Also if the unit is in good shape and you like it, it may be worth fixing even if it is the control panel. First try unplugging/removing power from the unit to see if it will reset. The computer on the control board may be confused. Next I would check the oven sensor Here is a good link with sensor and general stove info. http://www.applianceaid.com/elecrange.html If the sensor is good then odds are that the control board is toast.
__________________
| Display Modes | |
| Oven burning everything no matter what I set it at. | DDHauto | Oven Repair (including Ranges and Cooktops) | 2 | 10-17-2010 06:29 AM |
| Maytag double oven WIRE BURNING OUT | rsabbag | Oven Repair (including Ranges and Cooktops) | 1 | 12-03-2009 07:32 PM |
| Microwave oven burning smell and not heat up | sonche | Microwave Repair | 0 | 11-06-2009 09:37 PM |
| Amana oven burning food | kamohlf1 | Oven Repair (including Ranges and Cooktops) | 0 | 04-15-2009 01:00 PM |
| Gas Oven not burning | C5Steve | Oven Repair (including Ranges and Cooktops) | 8 | 11-05-2007 11:30 AM |
