| » Jenn-Air Wall Oven - Beeps with Code 'FC' |
Model Number: JJW9527BAW Brand: Jenn-Air Age: 5 - 10 years
Hello: (Note: I posted this on 10/19 and got no replies - I called your 877-# today and the woman I spoke with suggested I re-post it. You can also reply directly to my email if you prefer; janknut@yahoo.com . ) I'm getting a near-constant (goes away a few seconds if you press Cancel) code '-FC-' with beeping on this unit. The only way to 'stop' it is to cut the power at the breaker. I did not see this code ('FC') listed in your guide, but did see a few related posts. FC code jenn-air new clock just installed and Alarm FC Worth noting here is that I had a 'fading LED then no LED' issue one month ago; I replaced a capacitor (the 'C3' specifically) on the control board which solved the LCD issue, so I'm wondering if perhaps the control board ribbon connection getting fussy could be the cause of this, or if I have a more serious problem. Any / all help and suggestions appreciated. Thank you, Jan ps Further information about the prior repair I performed is here: http://www.fixya.com/support/t313759...l_not_light_up Ads By Google Related Models |
Hi:
In my case, this appears to have been due to a loose power connection going into the LCD panel control board. It appears that when I did the initial repair, I plugged it in 'just enough' for it to work for a while, until a bump or something similar caused to connection to fail. -JKT |
| Display Modes | |
| Jenn Air Wall Over Code 'FC' | Janmon | Oven Repair (including Ranges and Cooktops) | 0 | 10-19-2010 02:21 PM |
| F-2 Error Code on Jenn-Air Wall mount Oven | moleman | Oven Repair (including Ranges and Cooktops) | 0 | 03-04-2010 05:07 PM |
| Jenn-air wall oven | dem1969l@fast.net | Oven Repair (including Ranges and Cooktops) | 0 | 08-27-2009 10:14 AM |
| Jenn Air Wall Electric Wall Oven | WILLIAM SHIVER | Oven Repair (including Ranges and Cooktops) | 3 | 05-20-2009 12:56 AM |
| Jenn air wall oven | LesleyFarm | Forum Announcements | 0 | 08-01-2008 03:38 PM |
