Discuss
Electronic Control Assembly
 in
I have a Jenn Air built in oven that I bought about 10 years ago. Two years ago I had
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electronic Control Assembly
  #1 (permalink)
Old 10-28-2008, 08:07 AM
Junior Member
coollx is on a distinguished road
Default Electronic Control Assembly
Model Number: W304OOB   Brand: Jenn-Air   Age: 5 - 10 years
I have a Jenn Air built in oven that I bought about 10 years ago. Two years ago I had to replace the "electronic oven control assembly" which has the display showing clock, temp, mode,etc. Now the display is so dim you can hardly read it and probably have to bit the bullet and buy another one ($125+ s&h). In fact, when you set the oven for bake and pre-heat the display goes out completely.
I called Jenn Air but they couldn't/wouldn't help me since the actual oven is out of warranty. It just seems crazy that this control unit hasn't lasted more than two years.
Has anyone else had this same problem with the Jenn Air ovens?
Ads By Google
Related Models
Frigidaire WA24F4DTFB Gib(v4) / Top Load Washer
Frigidaire WA24F4WTFA Gib(v2) / Automatic Washer
Frigidaire WA24F4WTFB Gib(v3) / Top Load Washer
Frigidaire WA24P2DTFB Gib(v2) / Top Load Washer
Frigidaire WA24P2DVFA Gib(v2) / Top Load Washer
Frigidaire WA24P2WSFA Gib(v1)
Frigidaire WA24P2WSFB Gib(v2)
Frigidaire WA24P2WTFA Gib(v1) / Automatic Washer
Frigidaire WA24P2WTFB Gib(v1) / Top Load Washer
Frigidaire WA24P2WVFA Gib(v1) / Top Load Washer
Frigidaire WA24P2WVMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMA Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMC Gib(v1) / 24 " Washer
Frigidaire WA27F2WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F4WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M4WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M6WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M6WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M8WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M8WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA28D3WSFA Gib(v3)
Frigidaire WA28D4WSFA Gib(v4)
Frigidaire WA28D4WTFA Gib(v1) / Automatic Washer
Frigidaire WA28D5WSFA Gib(v5)
Frigidaire WA28D7WSFA Gib(v6)
Frigidaire WA28F2DTFB Gib(v5) / Top Load Washer
Frigidaire WA28F2WTFA Gib(v5) / Automatic Washer
Frigidaire WA28F2WTFB Gib(v1) / Top Load Washer
Frigidaire WA28F2WTFC Gib(v1) / Top Load Washer
Frigidaire WA28M2DTFB Gib(v6) / Top Load Washer
Frigidaire WA28M2WTFA Gib(v4) / Automatic Washer
Frigidaire WA28M2WTFB Gib(v2) / Top Load Washer
Frigidaire WA28M2WTFC Gib(v2) / Top Load Washer
Frigidaire WA28M4DTFB Gib(v7) / Top Load Washer
Frigidaire WA28M4WTFA Gib(v3) / Automatic Washer
Frigidaire WA28M4WTFB Gib(v3) / Top Load Washer
Frigidaire WA28M4WTFC Gib(v3) / Top Load Washer
Frigidaire WA28M4YTFB Gib(v9) / Top Load Washer
Frigidaire WA28M6DTFB Gib(v8) / Top Load Washer
Frigidaire WA28M6WTFA Gib(v2) / Automatic Washer
Frigidaire WA28M6WTFB Gib(v4) / Top Load Washer
Frigidaire WA28M6WTFC Gib(v4) / Top Load Washer
Frigidaire WA28S2WSFA Gib(v7)
Frigidaire WA3900AWL1 Frg(v4) / 27 " Washer
Frigidaire WA3900AWL2 Frg(v4) / 27 " Washer
Frigidaire WA3900AWW1 Frg(v3) / 27 " Washer
Frigidaire WA3900AWW2 Frg(v3) / 27 " Washer
Frigidaire WA3900AWW3 Frg(v1) / 27 " Washer
Frigidaire WA4720RW1 Frg(v1) / 27 " Washer
Frigidaire WA4720RW2 Frg(v1) / 27 " Washer
Frigidaire WA4900ADD1 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD2 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD3 Frg(v2) / 27 " Washer
Frigidaire WA4900AWW1 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW2 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW3 Frg(v3) / 27 " Washer
Frigidaire WA4900RW1 Frg(v1) / 27 " Washer
Frigidaire WA5800ADD1 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD2 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD3 Frg(v1) / 27 " Washer
Frigidaire WA5800AWW1 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW2 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW3 Frg(v2) / 27 " Washer
Frigidaire WA5800RW1 Frg(v2) / 27 " Washer
Frigidaire WA5820RW1 Frg(v1) / 27 " Washer
Frigidaire WA5820RW2 Frg(v1) / 27 " Washer
Frigidaire WA6500ADD1 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD2 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD3 Frg(v3) / 27 " Washer
Frigidaire WA6500AWW1 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW2 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW3 Frg(v4) / 27 " Washer
Frigidaire WA6520AL1 Frg(v2) / 27 " Washer
Frigidaire WA6520AL2 Frg(v2) / 27 " Washer
Frigidaire WA6520AW1 Frg(v1) / 27 " Washer
Frigidaire WA6520AW2 Frg(v1) / 27 " Washer
Frigidaire WA6620RW1 Frg(v1) / 27 " Washer
Frigidaire WA6620RW2 Frg(v1) / 27 " Washer
Frigidaire WA6900RW1 Frg(v3) / 27 " Washer
Frigidaire WA7200ADD1 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD2 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD3 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW1 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW2 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW3 Frg(v2) / 27 " Washer
Frigidaire WA7400PW0 Frg(v1) / 27 " Washer
Frigidaire WA7400PW1 Frg(v1) / 27 " Washer
Frigidaire WA7400PW2 Frg(v2) / 27 " Washer
Frigidaire WA8600PW0 Frg(v1) / 27 " Washer
Frigidaire WA8600PW1 Frg(v1) / 27 " Washer
Frigidaire WA8600PW2 Frg(v2) / 27 " Washer
Frigidaire WA8800PW0 Frg(v1) / 27 " Washer
Frigidaire WA8800PW1 Frg(v1) / 27 " Washer
Frigidaire WA8800PW2 Frg(v2) / 27 " Washer
Frigidaire WAA053M7A1 White Westinghouse Air Conditioner
White Westinghouse WAA060M7C1 White Westinghouse/air Conditioner
Frigidaire WAB057P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067F7B2 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067T7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067W7B1 Wwh(v0) / Air Conditioner
Frigidaire WAB077F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077F7B3 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077S7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB077Y7B1 Wwh(v0) / Room Air Conditioner
  #2 (permalink)
Old 11-02-2008, 03:28 PM
Junior Member
Default Electronic Control Assembly Problem For Second Time In Two Years?
Anyone know whether this is a common problem with the control assembly on this model or ovens in general?
Or is something else possibly causing this assembly to go bad?
Thank you.
  #3 (permalink)
Old 11-02-2008, 04:10 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I have serviced two Amana ovens with the control just above the door. The first one blew out when the door gasket started to leak hot air on the control!!
This next one took 13 years to fail, not too bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electronic Clock Control Assembly harry578 Oven Repair (including Ranges and Cooktops) 0 11-21-2009 11:37 AM
Electronic oven control assembly I did something wrong... Gary Hagen Oven Repair (including Ranges and Cooktops) 1 11-08-2008 03:33 AM
Electronic Control assembly Cartographer Dishwasher Repair 2 10-28-2008 12:47 PM
GE Electronic Oven Control Assembly tomv Oven Repair (including Ranges and Cooktops) 0 03-29-2008 06:22 PM
Electronic Oven Control Assembly PMH Oven Repair (including Ranges and Cooktops) 0 03-29-2008 02:33 PM
