glkearns
#1 Posted : Sunday, October 26, 2008 1:47:51 PM(UTC)
glkearns
Friday my wife called me at work saying the oven wouldn't light, and I just got around to checking it out this morning. The oven ignitor sparked 3 times (not long enough to light) then nothing. So I tried the Broiler, it clicked and lit right up, then I tried the oven again and no clicks. Then tried the broiler again and no clicks. Is it possible/likely that both ignitors decided to die at the same time or it something else?
Thanks for any replies
Greg
#2 Posted : Monday, October 27, 2008 9:33:16 AM(UTC)
Hi Greg,
Most likely the problem is a bad spark module (inside the control panel). It comes with the installation instructions.
- The part number for the spark module is AP3672576
glkearns
#3 Posted : Monday, October 27, 2008 7:28:48 PM(UTC)
glkearns
Thanks Gene, I found a tech guide online and just finished the ac/dc voltage tests, and sure enough it's a bad spark moudule. Thank you for the part number. It looks easy enough to replace.
Greg
#4 Posted : Monday, October 27, 2008 7:56:51 PM(UTC)
Keep us posted.
glkearns
#5 Posted : Thursday, October 30, 2008 9:13:04 PM(UTC)
glkearns
So the new spark module showed up today and I installed it....No dice. Did a complete diagnosis (following the flow chart) not just diagnosing the spark module. Now it looks like the spark module was ok, and I need a new gas control valve. Can you refrence that part for me?
http://appliancehelp.hypermart.net/DSI_manual.pdf
page 23/24's flow chart. My wife thinks I should call an appliance repair guy, and now that I am this far in I don't want to. It's a new challenge.
Thanks for any info.
Greg
glkearns
#6 Posted : Thursday, October 30, 2008 9:19:46 PM(UTC)
glkearns
http://partsfiles2.tap.net/Cooking/GS563LXSQ0.pdf
Here's a link to all the parts for this range in case this helps anyone else in my shoes later on.
Greg
glkearns
#7 Posted : Thursday, October 30, 2008 9:29:27 PM(UTC)
glkearns
Just ordered my part. Will keep you posted.
Greg
#8 Posted : Thursday, October 30, 2008 10:06:22 PM(UTC)
Did you check the valve/regulator as described in your manual on page 17?
glkearns
#9 Posted : Tuesday, November 4, 2008 8:24:10 AM(UTC)
glkearns
All fixed. The long and short of the whole thing is, the first time I did the electrical diagnosis I started diagnosing the problem at the spark module as opposed to starting at the beginning and working through all of the potential bad parts. Now I have a new spark module to keep track of until it decides to go bad. Thanks for the help
Greg
#10 Posted : Tuesday, November 4, 2008 1:35:49 PM(UTC)
Greg,
I'm glad you were able to fix it.
