| » Amana ignitor will not heat |
Model Number: ACS3350AB Brand: Amana Age: 1 - 5 years
Replaced the Amana (ACS3350AB) oven igniter 18 months ago with perfect results. Oven won't light again...so I once again replaced the igniter using great care to avoid touching critical part...no success...igniter does not glow or even begin to heat up...any suggestions on diagnosis and next steps? Just used voltage meter to check the connection for the igniter...turned oven to "bake" and no sign of juice coming from the connection...
Ads By Google Related Models Last edited by wkooist : 10-26-2008 at 01:52 PM. Reason: Checked connection with voltage meter |
Unplug the oven, and go down to the gas valve, and pull the wires off the gas valve, and see if you get a continuity reading. If not replace it. After that it would be the control. Tom ********************************************
| Display Modes | |
| No heat in oven, ignitor good | joebuehler | Oven Repair (including Ranges and Cooktops) | 3 | 12-12-2009 04:37 PM |
| How to install Amana gas range oven ignitor | vic@moment.net | Oven Repair (including Ranges and Cooktops) | 0 | 10-24-2009 08:30 AM |
| Ignitor connectors for Amana range | KarlHungus | Oven Repair (including Ranges and Cooktops) | 2 | 08-31-2009 05:29 PM |
| Dryer wont heat. ignitor turns on. | jkaj3000 | Dryer Repair | 10 | 08-17-2009 07:51 PM |
| Amana Stove Ignitor Trouble | acostafam | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 08:19 PM |
