| » oven won't work |
A model number may help others help you
Model Number Locator Could be a number of things. Many units have an overheat thermostat attached either to the top or back of the oven which can cause problems. If the oven is indicating that it is ready when it is not it could be the oven sensor. There are other possibilities depending on the wiring. Here is a good site with basice stove repair help. http://www.applianceaid.com/erange.html
__________________
Thanks for the reply. Where would the model # be locate? I looked inside the door and located what appeared to be a serial number. Nothing works on the control panel not even the clock the screen has no power. the only thing that works is the stove top.
Here is the model number locator from the Whirlpool website
http://www.whirlpool.com/service/modelnumber.jsp
__________________
Replacement parts for RF362lxts models | AppliancePartsPros.com Here is a manual https://secured.whirlpool.com/Servic...LE/8178042.pdf Unit does show a thermal fuse Item 26 in Section 3, but I think it is the one for just the broil element. If you look at the wiring diagram Page 6-1 it also does show a none resettable fuse as part of the brown wire going to the control board. Not sure I totally trust the wiring diagram as it shows a separate power supply which I cannot find in the parts. They may well still have an inline fuse built into one of the wires.
__________________
So a non resetable fuse has to be replaced? Would that fuse cause the whole display board to go out? Thanks for the manual by the way. According to Whirlpool agent on phone such a manual does not exist. go figure. Also this type of problem doesn't officially exist with these units despite the many threads that say it does.
Not 100% sure on this but since it shows it in a power supply line I would say yes. Not even sure that you have one but it is well worth a look. Often they are just a bulge in a wire.
__________________
| Display Modes | |
| GE Profile gas oven doesnt work broiler and top work fine | repondtomehere | Oven Repair (including Ranges and Cooktops) | 3 | 05-01-2011 11:45 AM |
| Surface Burners work OK, Oven dead, no control light turns on for oven | Whirlyone | Oven Repair (including Ranges and Cooktops) | 0 | 06-07-2010 07:24 AM |
| oven bake or broil does not work but all top burners do work | carbatt | Oven Repair (including Ranges and Cooktops) | 4 | 05-25-2010 09:08 AM |
| oven ignitor not clicking, but pilot will light manually and then the oven will work | rosscol | Oven Repair (including Ranges and Cooktops) | 0 | 09-10-2008 05:37 PM |
| oven ignitor not clicking, but pilot will light manually and oven work then | rosscol | Oven Repair (including Ranges and Cooktops) | 1 | 09-03-2008 04:30 PM |
