Discuss
Oven and broiler doesn't work GE JGBS23BEW4WH
 in
My GE JGBS23BEW4WH gas oven doesn't work. The oven light works. However, nothing glows, there is no gas smell either.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven and broiler doesn't work GE JGBS23BEW4WH
  #1 (permalink)
Old 10-25-2008, 03:31 PM
Junior Member
cdnpatriot is on a distinguished road
Default Oven and broiler doesn't work GE JGBS23BEW4WH
Brand: -brand-   Age: Less than 1 year
My GE JGBS23BEW4WH gas oven doesn't work. The oven light works. However, nothing glows, there is no gas smell either. Clock and stove top burners work. Are there things I should try to replace first starting with the cheapest and most probable?
Anyone have a link to a technical guide for this other than the user manual?
This unit is about 15 years old, perhaps I should just purchase another entry level one?
  #2 (permalink)
Old 10-25-2008, 04:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is check if there is 120VAC to the oven igniter while the thermostat calls for heat.
If there is 120VAC then the problem is a bad igniter.
If there is no 120VAC then the problem is a bad oven thermostat.
- The part number for the oven igniter is AP2020569
- The part number for the oven thermostat is AP2623073
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-25-2008, 06:26 PM
Junior Member
Default
Thanks. I checked it using my Multimeter when I turned it on it read 199.5 V.
One thing I don't understand though is how this works. How does it know to release gas? Right now it's not releasing any at all.
  #4 (permalink)
Old 10-25-2008, 06:41 PM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Wow! if your getting 200 volts to the ignitors you have some serious trouble. The gas valve opens when the proper amount of currant draw is obtained from the ignitor if its a round one somewhere around 2.5 amps if it's flat it's a little higher
__________________
  #5 (permalink)
Old 10-26-2008, 07:06 AM
Junior Member
Default
My apologies I meant 119.5 volts.
Left it on for 15 minutes but no gas released at all.
  #6 (permalink)
Old 10-27-2008, 08:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can learn how the oven igniter works from one of our previous posts: Oven won't lite?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile gas oven doesnt work broiler and top work fine repondtomehere Oven Repair (including Ranges and Cooktops) 3 05-01-2011 11:45 AM
Oven & broiler do not work Tomtom6 Oven Repair (including Ranges and Cooktops) 3 07-01-2009 11:21 PM
GE Broiler Won't Work When Oven Hot AnthonyT Oven Repair (including Ranges and Cooktops) 0 01-19-2009 08:19 AM
Oven & Broiler don't work edv Oven Repair (including Ranges and Cooktops) 0 11-12-2007 08:16 PM
GE Oven - Broiler does not work martincregg Oven Repair (including Ranges and Cooktops) 1 09-01-2007 10:46 AM
