| » Maytag Gemini Error Code F1-4 |
Model Number: MER6770 Brand: Maytag Age: 5 - 10 years
I just cleaned the lower oven today (self cleaning) and once the cycle was completed it started to beep and a code F1-4 was displayed on the panel. I tried to cancel but it won't. The upper oven door unlocked but the lower oven door will not unlock. When I try pressing any of the buttons on the panel such as cook and so on it just beeps and says LOCKED on the panel.
Any suggestions, Thank you. Ads By Google Related Models |
Hi Bondy,
"F1-4" error code means "Runaway temperature, lower oven". The first thing I would do is check the lower oven temperature sensor. Pull the range out, remove the rear cover and locate the sensor wire harness to the control board. Measure the sensor resistance at the control board. Normally it suppose to be about 1100 Ohms at the room temperature. Also check the sensor wire harness and the sensor plug. If the resistance reads wrong then replace the oven sensor. If there is nothing wrong then the control board has to be replaced. - The part number for the oven sensor is AP204836 - The part number for the control board is AP204841 Here are the break down diagrams for the Maytag Gemini range Model MER6770AAB Gene. P.S.You can find the complete instructions on how access the lower oven door lock in the Service manual..
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Maytag Gemini F1-1 Code | ijourneaux | Oven Repair (including Ranges and Cooktops) | 0 | 09-18-2009 11:26 AM |
| maytag mde9700ayw error code e5 | scottclk | Dryer Repair | 0 | 08-23-2009 04:08 PM |
| Maytag Gemini Error Code problem | FPWD | Oven Repair (including Ranges and Cooktops) | 11 | 06-26-2009 11:10 AM |
| Maytag refrig error code | Markie21 | Refrigerator & Freezer Repair | 3 | 04-15-2009 09:23 PM |
| Maytag refrig error code | Markie21 | Refrigerator & Freezer Repair | 1 | 04-02-2009 06:37 PM |
