shassoldt
#1 Posted : Thursday, October 23, 2008 8:22:51 AM(UTC)
shassoldt
Broiler igniter comes on and burns bright. Gas enters the broiler element, ignites, but is very low, like valve has not completely opened. Oven element is working fine.
#2 Posted : Thursday, October 23, 2008 7:40:33 PM(UTC)
Most likely the problem is a weak igniter. If you need the part number, post the complete model number please.
shassoldt
#3 Posted : Thursday, October 23, 2008 8:32:23 PM(UTC)
shassoldt
I guess I am confused. The igniter is glowing bright and the gas is igniting, but is like barely on. Would a weak igniter cause this? Model is Maytag CRG9700BALL it is set to work with propane.
Thanks!
#4 Posted : Friday, October 24, 2008 11:34:05 AM(UTC)
You can learn how the igniter works from one of our previous posts: http://forum.appliancepartspros...1897-oven-wont-lite.html
In your case the current drawn by the igniter is about 3.2 amps, causing the gas valve not to open completely.
- The part number for the igniter is AP205873
Here are the break down diagrams for the Maytag range Model CRG9700BAL
shassoldt
#5 Posted : Sunday, October 26, 2008 5:03:38 AM(UTC)
shassoldt
Gotcha! Thanks for the help. I will get the part ordered and go from there.
#6 Posted : Monday, October 27, 2008 6:58:46 PM(UTC)
Keep us posted.
shassoldt
#7 Posted : Sunday, November 2, 2008 7:20:17 PM(UTC)
shassoldt
Well I replaced the igniter and the problem is still the same, broiler lights, but stays on a very low setting, like ti valve has not opened all of the way. What do I check next?
#8 Posted : Monday, November 3, 2008 11:56:33 AM(UTC)
Remove the Broil burner. Unscrew the orifice and clean it. Assemble it back and adjust the flame by slowly turning the orifice.
If it would not help then replace the gas valve.
- The part number for the gas valve is AP4098213
shassoldt
#9 Posted : Monday, November 3, 2008 7:52:41 PM(UTC)
shassoldt
Thanks - I'll give her a try. I am pretty sure we replaced the gas valve last year when we were having problems with the lower (baking) element. Hopefully a good cleaning will do the trick!
Oven Broiler Always on High (Oven Repair (including Ranges and Cooktops))
by tolinrome 10/7/2023 12:17:48 PM(UTC)
no power to upper oven broiler ignitor (Oven Repair (including Ranges and Cooktops))
by Bill Patterson 2/9/2021 9:24:54 AM(UTC)
KitchenAid KGRS505XSS03 double oven broiler (Oven Repair (including Ranges and Cooktops))
by Y3Kready 5/18/2020 12:29:39 PM(UTC)
Electric Wall Oven broiler element stays on (Oven Repair (including Ranges and Cooktops))
by magicman1963 12/26/2016 6:29:18 PM(UTC)
Frigidaire wall oven broiler element not working (Oven Repair (including Ranges and Cooktops))
by rpdandy 9/11/2016 3:24:37 PM(UTC)
oven broiler help (Oven Repair (including Ranges and Cooktops))
by JonN 10/5/2015 2:09:57 PM(UTC)
Frigidaire Oven broiler not working (Oven Repair (including Ranges and Cooktops))
by isitjustme 8/28/2014 12:43:06 PM(UTC)
Upper oven broiler not working (Oven Repair (including Ranges and Cooktops))
by Johnswales@bellsouth.net 12/14/2013 6:12:51 AM(UTC)
Older GE oven broiler not working (Oven Repair (including Ranges and Cooktops))
by rabatvilla 3/7/2013 5:08:51 PM(UTC)
Whirpool oven broiler element not working (Oven Repair (including Ranges and Cooktops))
by Dr_Paul 6/23/2012 12:32:49 PM(UTC)
Oven broiler turns on in every bake mode (Oven Repair (including Ranges and Cooktops))
by gbourassa 4/24/2012 12:09:13 PM(UTC)
Amana Oven Broiler and Bake Shorted (Oven Repair (including Ranges and Cooktops))
by humble_master 3/5/2011 2:01:29 PM(UTC)
oven broiler ignitors (Oven Repair (including Ranges and Cooktops))
by Sammy D - Chicago 11/17/2010 7:33:07 AM(UTC)
Gas Oven Broiler Works but oven to bake will not heat (Oven Repair (including Ranges and Cooktops))
by Lisa Cline 11/11/2010 11:06:32 AM(UTC)
GE gas oven Broiler knob/switch malfunction (Oven Repair (including Ranges and Cooktops))
by 1consumer 7/27/2010 11:31:46 AM(UTC)
