Discuss
Error code 21 on Thermador
 in
I replaced the board 2 years ago and fixed the problem but now have an error code of 21 -
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Error code 21 on Thermador
  #1 (permalink)
Old 10-18-2010, 06:56 PM
Junior Member
CAA111 is on a distinguished road
Default Error code 21 on Thermador
Model Number: pgr484gdzs   Brand: Thermador   Age: 5 - 10 years
I replaced the board 2 years ago and fixed the problem but now have an error code of 21 - is this the board again? The range is connected to a surge protector - do I need a better one or is this just an unfortunate common problem.
Ads By Google
Related Models
Maytag PGR5702BDH Range - F/s Std Gas
Maytag PGR5702BDT Range - F/s Std Gas
Maytag PGR5705BDH Range - S/c F/s Gas
Maytag PGR5705BDT Range - S/c F/s Gas
Maytag PGR5710BDC Range - S/c F/s Gas
Maytag PGR5710BDQ Range - S/c F/s Gas
Maytag PGR5710BDW Range - S/c F/s Gas
Maytag PGR5715BDQ Range - S/c F/s Gas
Maytag PGR5715BDW Range - S/c F/s Gas
Maytag PGR5720LDQ Range - S/c F/s Gas
Maytag PGR5720LDW Range - S/c F/s Gas
Maytag PGR5750LDQ Range - S/c F/s Gas
Maytag PGR5750LDS Range - S/c F/s Gas
Maytag PGR5750LDW Range - S/c F/s Gas
Maytag PGS3759BDB Range - S/c S/i Gas
Maytag PGS3759BDS Range - S/c S/i Gas
Maytag PGS3759BDW Range - S/c S/i Gas
General Electric PGS908BEM1BB Gas range
General Electric PGS908CEM1CC Gas range
General Electric PGS908SEM1SS Gas range
General Electric PGS908WEM1WW Gas range
General Electric PGS975BEM1BB Gas range
General Electric PGS975SEM1SS Gas range
General Electric PGS975WEM1WW Gas range
Amana PGT-151UWW Range - S/c S/i Ddraft Gas
Amana PGT-183UWW Range - S/c S/i Ddraft Gas
Amana PGT120UB Surface Unit - Gas
Amana PGT120UW Surface Unit - Gas
Amana PGT130 Surface Unit - Gas
Amana PGT130-UD Range - S/c S/i Ddraft Gas
Amana PGT130-UWW Range - S/c S/i Ddraft Gas
Amana PGT130UB1 Surface Unit - Gas
Amana PGT130UD Surface Unit - Gas
Amana PGT130UWW Surface Unit - Gas
Amana PGT130UWW1 Surface Unit - Gas
Amana PGT136 Surface Unit - Gas
Amana PGT136-UD Range - S/c S/i Ddraft Gas
Amana PGT136-UWW Range - S/c S/i Ddraft Gas
Amana PGT136UB1 Surface Unit - Gas
Amana PGT136UD Surface Unit - Gas
Amana PGT136UWW Surface Unit - Gas
Amana PGT136UWW1 Surface Unit - Gas
Amana PGT153 Surface Unit - Gas
Maytag PGT153  Surface Unit - Gas
Amana PGT153UWW Surface Unit - Gas
Maytag PGT153UWW  Surface Unit - Gas
Amana PGT193UB Surface Unit - Gas
Amana PGT193UB1 Surface Unit - Gas
Amana PGT193UB2 Surface Unit - Gas
Amana PGT193UK Surface Unit - Gas
Amana PGT193UW Surface Unit - Gas
Amana PGT193UW1 Surface Unit - Gas
Amana PGT193UWW1 Surface Unit - Gas
Amana PGT193UWW2 Surface Unit - Gas
Thermador PH30HQS
Thermador PH30ZS
Thermador PH36HQS
Thermador PH36ZS
Thermador PH42HQS
Thermador PH42ZS
Thermador PH48HQS
Thermador PH48ZS
Thermador PH54HQS
Thermador PH54ZS
General Electric PHE25MGTAFBB Refrigerator
General Electric PHE25MGTAFWW Refrigerator
General Electric PHE25PGTAFBB Refrigerator
General Electric PHE25PGTAFWW Refrigerator
Thermador PHE30US
Thermador PHE36US
Thermador PHE42US
Thermador PHE48US
Thermador PHE60US
General Electric PHG25MGTAFBB Refrigerator
General Electric PHG25MGTAFWW Refrigerator
General Electric PHG25PGTAFBB Refrigerator
General Electric PHG25PGTAFWW Refrigerator
Thermador PHI36S
Thermador PHI48QS
Thermador PHI54S
Thermador PHI60QS
Amana PHO-203-UD Range - S/c S/i Ddraft Gas
Amana PHO-203-UW Range - S/c S/i Ddraft Gas
Amana PHO-203-UWW Range - S/c S/i Ddraft Gas
Amana PHO303UB Surface Unit - Gas
Amana PHO303UK Surface Unit - Gas
Amana PHO303UWW Surface Unit - Gas
Frigidaire PHSC239DSB0 Frigidaire/refrigerator
Frigidaire PHSC239DSB1 Frigidaire/refrigerator
Frigidaire PHSC239DSB2 Frigidaire/refrigerator
Frigidaire PHSC239DSB3 Frigidaire/refrigerator
Frigidaire PHSC239DSB5 Frigidaire/refrigerator
Frigidaire PHSC239DSB7 Frigidaire/refrigerator
Frigidaire PHSC39EESS0 Frigidaire/refrigerator
Frigidaire PHSC39EESS1 Frigidaire/refrigerator
Frigidaire PHSC39EESS3 Frigidaire/refrigerator
  #2 (permalink)
Old 10-19-2010, 11:15 AM
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Hello,
The 2-1 error is a Potentiometer Failure. The potentiometer it's referencing is the temperature selector. It could be that that part is bad, or you have a bad wire or connection between it and the X3 plug on the relay board.
KC
  #3 (permalink)
Old 10-19-2010, 02:26 PM
Junior Member
Default
Quote:
Originally Posted by Servicer View Post
Hello,
KC
Any suggestions on how to check this - determine which part is bad?
  #4 (permalink)
Old 10-19-2010, 04:47 PM
Senior Expert
APP Volunteer
Default
You'll have to measure the resistance of the potentiometer, either at the part itself or at the X3 connection on the board.
At the potentiometer, if you measure across the pins that the white and red wire connect to, you'll read around 20.5k ohms when set to 350. If you measure from the x3 connection, you'll disconnect the harness and measure directly across the wires.
  #5 (permalink)
Old 10-19-2010, 07:04 PM
Junior Member
Default
Any description (location, how to get to it, etc) or diagram of potentiometer before I pull the range out this weekend and test it? Also, if it's is the actual part/potentiometer, do you know the part number?
  #6 (permalink)
Old 10-20-2010, 12:59 PM
Senior Expert
APP Volunteer
Default
To get to the back of the potentiometer, you'll need to remove the part of the cooktop that sits behind it, i.e. the burners, griddle or grill.
Attached are some pages from the service manual that pertain to the potentiometer.
The part number is 418329.
KC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador F7 Error PSU Oven Repair (including Ranges and Cooktops) 6 07-11-2012 04:20 PM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
Thermador Double Oven Error Code GatorFLHX Oven Repair (including Ranges and Cooktops) 0 01-12-2010 05:04 PM
Thermador oven self clean F2 error code Vic C Oven Repair (including Ranges and Cooktops) 0 01-09-2010 10:44 AM
Thermador oven F7 error code cherie40 Oven Repair (including Ranges and Cooktops) 0 12-28-2009 11:56 AM
