Discuss
service wire and breaker size
 in
what is the breaker and wire size required to run Model number JENN-AIR SCE30600B Range ? the distance to the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » service wire and breaker size
  #1 (permalink)
Old 10-18-2010, 05:20 PM
Member
whsydddy9 is on a distinguished road
Default service wire and breaker size
Brand: Jenn-Air   Age: 1 - 5 years
what is the breaker and wire size required to run Model number JENN-AIR SCE30600B Range ? the distance to the breaker box is approximately 30 feet. I was told this is a 6800 watt range, 240 volt.
Ads By Google
  #2 (permalink)
Old 10-18-2010, 05:33 PM
Junior Member
Keith Hocky is on a distinguished road
Default
Quote:
Most ranges use a 2 pole-50 amp breaker, #6 aluminum range cable (3 individual wires with ground) or #8 Cu 4 wire. Either will do for a 30' distance. To be sure you have the right size wire do a little math.
Wattage of the Range= Current x Voltage
soooo... divide the Wattage by the voltage to get your current flow.
Then round up for safety! If the current comes out to 42 Amps use a 50 amp breaker.
Hope this helps!
  #3 (permalink)
Old 10-18-2010, 05:46 PM
Member
Default
Thank You...I appreciate the info!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
service wire and breaker size whsydddy9 Oven Repair (including Ranges and Cooktops) 1 10-19-2010 03:41 AM
Wire terminal size on heating element sgwynn Dryer Repair 3 03-24-2010 06:29 AM
what size breaker do I need crazymom041 Oven Repair (including Ranges and Cooktops) 4 12-25-2009 06:27 AM
Breaker size for upgraded A/C candlepower Heating, Ventilation, and Air Conditioning (HVAC) 4 05-31-2009 06:39 PM
