Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Flat Top Electric Range (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/133261-flat-top-electric-range.html)
culily 10-18-2010 03:15 PM
Burners On Left Side Of Flat Top Electric Range Not Working
Gene 10-18-2010 05:07 PM
The problem can be a bad heating element or a bad switch for this burner. All parts have to checked for continuity to pinpoint bad parts.
Here are the breakdown diagrams and Replacement parts for General Electric JBP66BK3WH Electric range | AppliancePartsPros.com
Keith Hocky 10-18-2010 05:25 PM
Quote:
Not knowing your technical experience dealing with electricity its difficult to give you advice. I'd hate for you to zap yourself.
However, if you have an electrical tester, and feel comfortable enough that you won't shock yourself, check to see if you have electricity on both legs feeding the cooktop. If you do, then the problem is internal and you may have to remove the cooktop, after shutting off the breaker, to reach the appropriate connections. Get a good schematic and trace the lines, hopefully its a loose connection that will be a simple fix. If its not, check the make and model number and get the repair parts. Hopefully, someone with more experience will follow-up.
Remember always start simple when problem solving.
