Discuss
Help - instructions to install oven igniter
 in
Original Oven And Broiler Would Not Light Model #jgbc20gev3wh No Prior Troubleshooting
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Help - instructions to install oven igniter
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #21 (permalink)
Old 03-26-2008, 04:17 PM
2835AW 2835AW is offline
Junior Member
2835AW is on a distinguished road
Default G.e.oven Replaced Ignitor Oven Still Will Not Light
Model #jgbc20gev3wh
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #22 (permalink)
Old 03-26-2008, 04:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is check for 120V to the igniter while the oven thermostat calls for heat.
If there is no 120V, check the wires then bypass the thermostat and see if it works. If it does - replace the oven thermostat.
- The part number for the oven thermostat is AP2623073
__________________
Professional appliance repair services in Orange County, California.
  #23 (permalink)
Old 06-28-2008, 11:53 AM
bobit bobit is offline
Junior Member
bobit is on a distinguished road
Default
I am replacing the flat 3 3/4" igniter in my GE JGSP28 gas range. The one I bought locally does not have the matching snap connector. I forsee a problem because if I cut off the in-place connector half, there will not be enough wire sticking through the whole in the back of the oven to make a proper connection with the wire nuts.
Question: This is not a genuine replacement. They said it was a Kelvinator part. Is it possible that I could obtain a replacement that has the matching connector half? It would make life a lot easier.
  #24 (permalink)
Old 06-28-2008, 06:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the GE oven igniter with the quick disconnect plug is AP3202322
__________________
  #25 (permalink)
Old 06-29-2008, 06:57 PM
Junior Member
Default
Gene, Thanks for the prompt reply to my email of 6-28-08. You posted a photo of a flat ignitor in your 9-27-07 reply #3 to lrg51. It looks exactly like the part I need to replace. I checked the details and found the p/n is Maytag AP205873. In your reply you gave me p/n AP3202322. Am I missing something? Are they the same parts with different p/n?
Also, I asked if the igniter would come with a connector halve to match the quick connector halve on my GE model JGSP28WEK2WW. Please advise.
  #26 (permalink)
Old 06-30-2008, 11:40 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The igniter with the part number AP3202322 made by GE. The igniter with the part number AP205873 made by Maytag. They look very similar but I'm not sure if their plugs are identical. I would recommend to use the igniter made by GE .
__________________
  #27 (permalink)
Old 07-03-2008, 02:09 PM
ronlovell ronlovell is offline
Junior Member
ronlovell is on a distinguished road
Question Kenmore Gas Oven Won't Ignite
I have 115 volts comming to the ignitor and gas valve. I replaced both the ignitor and gas valve as both were bad. After installing both new parts the oven came on and worked like it should. Then the next time I went to use it again it would not work. Still have correct power to both. Pretty expensive parts for one time use.
Kenmore gas range....Model 911.7199180...Ser.# 0F60407
  #28 (permalink)
Old 07-07-2008, 01:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
ronlovell,
Please describe how did you measure voltage to these parts.
Did you check them for continuity?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven igniter kilowat Oven Repair (including Ranges and Cooktops) 12 10-25-2007 07:20 AM
oven igniter does't heat up poplin,earnest Oven Repair (including Ranges and Cooktops) 1 09-19-2007 07:12 PM
Control Board Installation Instructions tbj66 Refrigerator & Freezer Repair 3 09-11-2007 10:53 PM
Replaced the igniter and there is still no heat in my oven??!! Ruben Oven Repair (including Ranges and Cooktops) 1 08-21-2007 10:44 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
