Discuss
Help - instructions to install oven igniter
 in
which side faces the oven burner.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Help - instructions to install oven igniter
  #81 (permalink)
Old 10-26-2011, 06:20 PM
Junior Member
smith1326 is on a distinguished road
Default install igniter for oven
  #82 (permalink)
Old 10-28-2011, 04:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are no options. You can install it only one way.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #83 (permalink)
Old 11-18-2011, 05:22 PM
Admin / APP Team's Avatar
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
We now have a step-by-step video showing how to replace an oven igniter (either flat or round):
Part number: AP4012072
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #84 (permalink)
Old 12-02-2011, 09:08 AM
Junior Member
shirlt is on a distinguished road
Default Help with my GE Range Model #JB968K0K1CC
After cleaning cycle I have always gotten a F code. I have only used the clean 3 times on this range. This time I got the F2 which says (for an unknown reason the oven temp has exceeded the preset threshold. The only other code we got was fc, & it says this cod means that component has failed somewhere in door lock circuit. Even after unplugging for a long time we either had lock just clicking off & on constantly, or would not unlock. It is like the lock function is shorting out. Do you have any suggestions what this could be?
  #85 (permalink)
Old 12-03-2011, 10:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the problem is a bad oven control board, but there is a small chance for the door latch to be bad as well. Unfortunately there are no instrumental tests in such situation. I would replace the control board first.
- The control board Part number: AP3957552
Here are the breakdown diagrams and Replacement parts for General Electric JB968KK1CC Electric range | AppliancePartsPros.com
__________________
  #86 (permalink)
Old 05-08-2012, 12:04 PM
Junior Member
homer2 is on a distinguished road
Default
I have a Maytag MGR4451BDW Stove.
Only 2 of the 4 ignigtors work. I can move the burners around and they will spark in different spots.
I checked and there are 3 ignitors with the same part number and one with a different part number. The only difference I see is the one has a wider spade than the rest.
What would be the reason?
If I replace all the ignitors, will that fix my problem?
Homer
  #87 (permalink)
Old 06-11-2012, 01:48 PM
Junior Member
selder is on a distinguished road
Default
Ok so I've replaced the oven igniter, it worked so I put everything back together. Now it won't even come on. Seems to me like there would be a short or something somewhere but I don't know where to start. any help would be appreciated.
  #88 (permalink)
Old 06-11-2012, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What was the original problem?
What is the complete model number of the oven?
__________________
  #89 (permalink)
Old 06-15-2012, 08:38 AM
Junior Member
Default
sf377pegw1 its a whirlpool gas range. Oven won't light, but broiler and burners still do.
  #90 (permalink)
Old 06-16-2012, 06:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check for 120 VAC to the igniter while the control calls for Bake. Post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help -instructions to install oven thermador spark module alexcorea Oven Repair (including Ranges and Cooktops) 1 12-01-2009 06:35 PM
How to Install Igniter in this 12 yr old Oven Ann Yeager Oven Repair (including Ranges and Cooktops) 0 10-20-2009 05:17 PM
Help to install oven igniter jeep_cj5 Oven Repair (including Ranges and Cooktops) 7 09-30-2008 02:19 PM
Instructions to Install Electronic Oven Control gelefante Oven Repair (including Ranges and Cooktops) 1 03-11-2008 01:19 PM
oven igniter - how to install / access maytag wally Oven Repair (including Ranges and Cooktops) 0 11-21-2007 03:19 AM
