Discuss
Help - instructions to install oven igniter
 in
Originally Posted by Gene Yes Jim. It's very similar. Here are the breakdown diagrams and Broiler and oven burner replacement
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Help - instructions to install oven igniter
  #51 (permalink)
Old 06-10-2010, 02:57 PM
Junior Member
HondaJim is on a distinguished road
Default
Quote:
Here are the breakdown diagrams and Broiler and oven burner replacement parts for WHIRLPOOL KGST307HBL4 | AppliancePartsPros.com
Thanks Gen, This will be helpful
  #52 (permalink)
Old 06-10-2010, 06:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Jim. Keep us posted.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #53 (permalink)
Old 06-11-2010, 08:03 PM
Junior Member
halah is on a distinguished road
Default
Thank you so much for this thread. I've been all over the internet trying to figure out how to replace the igniter on my GE Spectra Range. I couldn't find anything that told me how to actually take the old igniter off until I found this thread.
I did have to make a trip to Home Depot to get new connectors and was talked into buying a stripping/crimping tool for $11, but now I having a working oven for the cost of parts and a tool. Yay!
Thank you so much for helping this silly girl feel like she can fix stuff in her condo.
  #54 (permalink)
Old 06-12-2010, 06:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad to see you happy!
__________________
  #55 (permalink)
Old 09-22-2010, 07:33 PM
Junior Member
anotherITgiy is on a distinguished road
Default
Hi. I have a GE Spectra XL44 model number JGB920BEC4BB. I originally though that my bake igniter had bit the dust because my oven takes about 35-45 min to preheat to 350/375. In trying to diagnose the issue I removed the bottom cover of the oven to expose the igniter and burner. I then preheated the oven to 400 and it reached the target temp in about 10 min. I then replace the bottom cover and again tried to preheat to 400 and it took over 45 min. Could the bottom cover be affecting the igniter/burner in some way? I also noticed that without the cover on the burner fired up in about 30 sec. With it back on it took over 2 min. Coincidence or could it be related in some way? I'm ready to buy a new igniter to see if that fixes it. What do you guys think?
Thanks for the help guys.
  #56 (permalink)
Old 09-22-2010, 07:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Before ordering the igniter I would inspect the burner for and clogged or burned through holes. If there any, order the burner. It comes with the igniter.
- The oven igniter Part number: AP2020569
- The Bake burner assembly Part number: AP3205796
Here are the breakdown diagrams and Replacement parts for General Electric JGB920BEC4BB Gas range | AppliancePartsPros.com
__________________
  #57 (permalink)
Old 09-23-2010, 08:09 AM
Junior Member
Default
The burner holes don't appear to be clogged and I don't see any visible holes elsewhere along the burner tube. Last night, while observing the burner without the bottom cover on I did noticed that the flame was even along the entire length of the burner, on both sides. I did not see any areas that were not lit, though I did notice that the flame started out fairly large and then after a few moments (maybe 30 sec after it lit) decreased in size for the remainder of the preheating. Do you think a new igniter would be the next logical step?
  #58 (permalink)
Old 09-23-2010, 06:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
There are a few venting holes in the oven floor. Try to check the flame looking through those holes, without removing the oven floor. Post the results.
__________________
  #59 (permalink)
Old 12-31-2010, 12:30 PM
Junior Member
ccroy is on a distinguished road
Default Hi, a couple of Hotpoint questions
I have a Hotpoint model RGB628GEJ1AD range. I received the ignitor, but no wire nuts. Should they have been included? Secondly I removed 4 screws, 2 on the ignitor and 2 on the back wall of the ove and the ignitor is now loose. However I have hardly any slack in the wires. Do I need to pull the range out from the wall? I assume if I do I need to disconnect the gas line? Lastly are ceramic wire nuts something a local hardware store might stock?
Thanks,
Chris
Quote:
Originally Posted by Admin / APP Team View Post
Correct
Yes, the wire nuts included are hi-temp resistant ceramic wire nuts.
  #60 (permalink)
Old 01-14-2011, 09:22 PM
Junior Member
Default Fixed It!
Not only was my ignitor bad, I had pinched wire that was shorting to the chassis just above the door near the burner controls.
Thanks for the part, but I am a little disapointed no one responded to my above post and I had to go to a local applicance store for the ceramic wire nuts. The counter guy said the ignitor should ship with them, so this looks like an oversight from the supplier or Appliance Parts Pros.
Anyway, all is well now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help -instructions to install oven thermador spark module alexcorea Oven Repair (including Ranges and Cooktops) 1 12-01-2009 06:35 PM
How to Install Igniter in this 12 yr old Oven Ann Yeager Oven Repair (including Ranges and Cooktops) 0 10-20-2009 05:17 PM
Help to install oven igniter jeep_cj5 Oven Repair (including Ranges and Cooktops) 7 09-30-2008 02:19 PM
Instructions to Install Electronic Oven Control gelefante Oven Repair (including Ranges and Cooktops) 1 03-11-2008 01:19 PM
oven igniter - how to install / access maytag wally Oven Repair (including Ranges and Cooktops) 0 11-21-2007 03:19 AM
