Discuss
Help - instructions to install oven igniter
 in
Hi, we've been having the same problem described in this thread with our Viking oven not heating up fast
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Help - instructions to install oven igniter
  #41 (permalink)
Old 09-10-2009, 10:22 AM
steelman steelman is offline
Junior Member
steelman is on a distinguished road
Default Viking Oven
Hi, we've been having the same problem described in this thread with our Viking oven not heating up fast enough. We had it serviced a few years back and the guy replaced the ignitors and charged us $350, so doing it myself sounds like the right plan.
I opened the oven and removed the bottom panel to expose the ignitors just to see what the job looks like. And it looks fairly simple to remove and replace those ignitors.
However, I turned the oven on to observe what is happening. Both ignitors turned on and started glowing pretty well. After several minutes the flames finally lit on one side, but not the other. And even the flame that lit would die out and then restart, almost like it had a bad gas flow.
Is this a sympton of bad ignitors or is there possibly another problem I should look at?
Thanks!
Steve
  #42 (permalink)
Old 09-13-2009, 07:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Steve,
If the igniter does not light the flame within 60-70 seconds then the igniter is bad.
Instead of paying to Viking very high price for the new igniters, you can use any flat igniter made by GE, Whirlpool or Frigidaire. They all are identical beside prices.
- The igniter Part number: AP2634719
__________________
  #43 (permalink)
Old 09-14-2009, 03:06 PM
Junior Member
Default
Thanks Gene. Will this part also replace the Viking Ignitor? It looks idential and I was told by someone else its the same part.
#12400035 Maytag Universal Flat Gas Range Oven Ignitor
  #44 (permalink)
Old 09-14-2009, 03:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, it will. As I said - all flat oven igniters (excluding the igniters with blue ceramic) are the same.
But the igniter with the Part number: AP2634719
which I posted in my previous reply is more than $7 cheaper than the igniter with
the Part number: 12400035
Part number: 12400035.
__________________
  #45 (permalink)
Old 09-20-2009, 10:44 AM
knaqib@gmail.com knaqib@gmail.com is offline
Junior Member
knaqib@gmail.com is on a distinguished road
Question Viking Oven and 12400035
I just tried replacing the ignitors in my Viking Oven with two 12400035 parts. All went smoothly. However, both of them failed to light. Any idea what could be wrong? Someone mentioned to me that the ignitors can have different amperage (current) requirements, but I haven,t seen any spec. Also, do the wire connections have a polarity, or are they exchangeable??
  #46 (permalink)
Old 09-21-2009, 11:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What was the original problem with the oven? Did the old igniters (both) glow?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven igniter kilowat Oven Repair (including Ranges and Cooktops) 12 10-25-2007 08:20 AM
oven igniter does't heat up poplin,earnest Oven Repair (including Ranges and Cooktops) 1 09-19-2007 08:12 PM
Control Board Installation Instructions tbj66 Refrigerator & Freezer Repair 3 09-11-2007 11:53 PM
Replaced the igniter and there is still no heat in my oven??!! Ruben Oven Repair (including Ranges and Cooktops) 1 08-21-2007 11:44 AM
