Discuss
Tappan Wall Oven Temp adjustment
 in
I have a Tappan Double Wall oven. Over ten years old but in beautiful condition The temperature on the ovens
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan Wall Oven Temp adjustment
  #1 (permalink)
Old 09-29-2007, 06:19 AM
jmdrapeau jmdrapeau is offline
Junior Member
jmdrapeau is on a distinguished road
Default Tappan Wall Oven Temp adjustment
Brand: Tappan   Age: More than 10 years
The temperature on the ovens is incorrect by approx 25 degrees and 20 degrees. Is there any way to adjust or replace something that can make the ovens true to temperature
  #2 (permalink)
Old 09-29-2007, 12:15 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is online now
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Thermostat controlled oven: Most thermostats have an adjustment screw which will allow you to make minor adjustments. If that doesn't help, you can replace the thermostat.
Digitally controlled oven: There is a way to adjust your oven control board. Read this article.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
temp in oven is wrong smpmagic Oven Repair (including Ranges and Cooktops) 5 12-02-2007 03:21 PM
Wall Oven light goes off and on by itself josie Oven Repair (including Ranges and Cooktops) 2 10-16-2007 09:56 AM
whirlpool electric wall oven problem devdry Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:30 PM
Tappan Wall Oven jake Oven Repair (including Ranges and Cooktops) 3 08-13-2007 11:53 PM
Oven Temp 60F low George Whitmore Oven Repair (including Ranges and Cooktops) 0 08-13-2007 04:08 PM
