Discuss
thermador cook N ventilation does not work
 in
Thermador COOK N VENT rising panel type. (I cannot locate the model #) Miele brand cooktop with thermador rising panel
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » thermador cook N ventilation does not work
  #1 (permalink)
Old 10-20-2008, 10:19 PM
Junior Member
frankpark is on a distinguished road
Default thermador cook N ventilation does not work
Brand: Thermador   Age: 1 - 5 years
Miele brand cooktop with thermador rising panel ventilation type: Downdraft ventilation (possibly UCVM30FS)
Thermador brand cooktop ventilation switch does not work.(switch turns clockwise to speed 0,1,2,3)
The ventilation motor fan works but the switch does not work. How do I repair the switch?
Thank you!
Ads By Google
  #2 (permalink)
Old 10-21-2008, 10:42 AM
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Hello,
It sounds like you have a CVS30RS downdraft. Your problem is a bit contradictory. The speed selector switch is what runs the fan, so if the switch is not working the fan should not run. If the fan runs, but the speeds don't change you may have a problem in the motor or restrictive ducting.
So, is the problem that the fan runs, but does not change speeds, or is the fan actually not running?
KC
  #3 (permalink)
Old 11-10-2009, 10:39 AM
Junior Member
jneves is on a distinguished road
Default UCVM30FS Downdraft
I just bought a UCVM30FS downdraft with the 600 CFM blower unit. Had it installed yesterday everything worked great the first time I turned it on. Went up, changed fan speeds1, 2, 3 then back to 0 and push the button to turn off and it went down nicely. I cleaned up all the packaging and wiped the counter. My wife gets home and I call her over to show her and nothing, nothing at all. No up, no fan nothing. electrician was still outside so I called him in to check, plug has power, power is flowing through the pre-installed cable, but nothing happens.
Any ideas.
BTW, first time poster, I would really appreciate some feed back.
  #4 (permalink)
Old 11-10-2009, 12:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you just bought it then the best solution is to call Thermador for the warranty service.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #5 (permalink)
Old 11-11-2009, 08:27 AM
Junior Member
Default
Thanks Gene, I called yesterday and they will be out on Friday.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Cook Top JOES Oven Repair (including Ranges and Cooktops) 11 10-28-2009 09:52 PM
Thermador Cook n vent Aninie Oven Repair (including Ranges and Cooktops) 1 01-02-2009 05:54 PM
thermador stovetop ventilation shuster Oven Repair (including Ranges and Cooktops) 0 11-23-2008 11:23 AM
Thermador cook top pop flip Oven Repair (including Ranges and Cooktops) 2 05-13-2008 12:14 PM
Thermador Cook Top JOES Oven Repair (including Ranges and Cooktops) 0 04-10-2008 08:13 AM
