groundsup
#1 Posted : Thursday, October 14, 2010 4:04:07 AM(UTC)
groundsup
I just purchased a new Panel control for my unit. The oven was working but the light wasn't on so you couldn't see the time of temp. In the process of changing the board it unpluged from the the other board on the side of the oven. There are 2 possible conections to plug it into and i am not sure which one it goes into. There is a marking on both boards that reads J2 so i used that connection but it doesnt work. the control lights up but the oven won't heat up. I checked the two elements and the thermostat and they are fine. Again the oven worked less the light prior to my starting the repair. Any help would be appreciated as to which connection should i be using. Or any other possible saloutions to my problem.
groundsup
Freezer is not cooling, fan is not working, light not on, NEW control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:06:23 PM(UTC)
Freezer fan doesn't work, new control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:02:45 PM(UTC)
New control board flashing. (Refrigerator & Freezer Repair)
by Guest 3/30/2023 1:43:38 PM(UTC)
GE Top load, new controller board does not accept personality code (Washer Repair)
by tommalia@ttdsinc.com 3/10/2023 1:41:25 PM(UTC)
GE New control board blinks 4 zeros across display. (Refrigerator & Freezer Repair)
by JonEQuest 11/17/2020 10:24:01 AM(UTC)
new control board - frig. not working - help (Refrigerator & Freezer Repair)
by pmcag 4/30/2016 4:17:38 AM(UTC)
Washer fills, no agitate, no spin. new control board (Washer Repair)
by JStiene 4/6/2015 8:49:47 AM(UTC)
Removing control panel and installing new control board (Oven Repair (including Ranges and Cooktops))
by devronh 3/4/2014 6:27:03 AM(UTC)
New Control board not operating (Oven Repair (including Ranges and Cooktops))
by JimCowan 2/27/2014 9:52:56 AM(UTC)
No heat to oven or broiler even with New Control Board (Oven Repair (including Ranges and Cooktops))
by ovencrazy! 10/23/2013 9:21:55 PM(UTC)
Needs new control board every 3 years- why? (Refrigerator & Freezer Repair)
by checkerkitty 8/19/2013 8:42:17 AM(UTC)
New Control Panel (Oven Repair (including Ranges and Cooktops))
by DESwish 8/1/2013 8:49:39 AM(UTC)
Bosch Dishwasher alarm will not disable after installing new control module (Dishwasher Repair)
by nixima 7/30/2013 5:53:39 AM(UTC)
New Control Panel- start button won't work (Dishwasher Repair)
by nejennie 6/18/2013 4:00:03 PM(UTC)
new control module displaying 5 steady lights (Dishwasher Repair)
by treborssag 6/16/2013 4:24:56 PM(UTC)
